error
error
Postby knome » Sun Dec 24, 2006 11:25 am
I dont' know what to do, i'm getting an error when i try and read from my ecu with ecuflash, Here is the log:
[00:07:18.140] Version 1.29.906
[00:07:18.171] 8 memory models read.
[00:07:19.937] 140 ROM metadata models read.
[00:07:19.937] checksum module "subarudbw" loaded.
[00:07:19.937] flashing tool "wrx02" loaded.
[00:07:19.937] flashing tool "wrx04" loaded.
[00:07:19.937] flashing tool "sti04" loaded.
[00:07:19.937] flashing tool "sti05" loaded.
[00:07:19.937] flashing tool "mitsukernel" loaded.
[00:07:19.937] flashing tool "mitsukernelocp" loaded.
[00:07:19.937] flashing tool "mitsubootloader" loaded.
[00:08:08.000] denso02_bootloader_cmd_start
[00:08:09.562] denso02_bootloader_cmd_start
[00:08:10.781] denso02_bootloader_cmd_start
[00:08:12.000] denso02_bootloader_cmd_start
[00:08:13.218] denso02_bootloader_cmd_start
[00:08:13.656] kernel get version
can anyone help?
btw i have a subaru 02 subaru wrx AT
knome
Postby knome » Sun Dec 24, 2006 12:00 pm
well i found out what was happening that was causing it to not work now ecu explorer will not load. It just sits there saying dissconnected even when the engine is turned on and i can get data readings from enginuity. Anyone have any ideas why this would happen?
knome
kernel
Postby l.alvarez » Thu Dec 28, 2006 9:51 pm
knome wrote:well i found out what was happening that was causing it to not work now ecu explorer will not load. It just sits there saying dissconnected even when the engine is turned on and i can get data readings from enginuity. Anyone have any ideas why this would happen?
How do you fix the kernel problem
l.alvarez
