06 wrx front mount
06 wrx front mount
Postby billscola » Thu Dec 28, 2006 5:13 pm
just startin have the cable please help with the basics i downloaded my ecu bue all parameters r in gray thanks
billscola
Postby cboles » Wed Jan 10, 2007 3:48 pm
EcuFlash is not showing any tables for your ROM because no XML definition files has been made for it yet. XML definition files are collections of information about what tables are in a ROM, where they are located in memory, how the numbers in the ROM scale into human readable units, etc. Making definitions is a time consuming process that must be repeated for each different ROM version. I try to contribute definitions when I can, but ultimately it is up to the members of the OpenECU community to help with this aspect of the project. By submitting your ROM image to
http://forums.openecu.org
and
http://enginuity.org
you should be able to get help from others that share an interest in the same vehicle you have. Please also be sure to send me a copy of your ROM as well for our library and future testing.
