Is there a Max number of flashes in an EVO ECU?
Postby dustinr » Sat Dec 02, 2006 4:37 pm
Just wondering if there is a max number of flashes allowed and if so are there any tell-tale signs that your ECU is about to die?
dustinr
Postby ralliart » Fri Dec 08, 2006 3:48 pm
Yes 100/150 in theory :D but much of "tuner" exceed this limit :wink:
ralliart
Postby Freon » Fri Dec 08, 2006 4:00 pm
The datasheets for the flash memory say they are good to 100, but I've never heard of anyone blowing an ECU due to over flashing.
Postby flash » Mon Dec 11, 2006 1:32 pm
freon´s post is correct. the sheets say 100.
i have seen a ecu which has been programmed around 300times. this one have some problems with the internal flash.
if i want to reprogram it, sometimes some "segements" could not written to the ecu. i have to flash the segment 3 or 4 times.
flash
Postby C6ect.ect » Thu May 17, 2007 1:08 pm
100 times?
Hell, I've flashed about 1000 times to my ECU, no problems - except once I was in a hurry and started my car instead of key-on to ignition :lol: (I have my clutch position switch removed from bracket so it will start without clutch)
Good thing I didn't press "OK"
C6ect.ect
Postby 4tun8 » Thu Sep 20, 2007 12:01 pm
C6ect.ect wrote:100 times?
It would have flashed, ecuflash will turn the car off.
4tun8
