noob: which tatrix cable?
Postby mr_yellow » Fri Oct 14, 2005 1:35 pm
Hi guys,
I've been visiting this site off and on and recently wanted to get the tatrix cable to play around with it. However I noticed there's only one version of the cable on the tatrix site. What happened to the WRX version?
I heard it was sold out and a new version is in the works, but as the new one come out yet? Is the "generic" version still compatible with the WRX?
Also, Is there a "dummy's guide" to all of this?
Thanks!
mr_yellow
Postby west_minist » Sat Oct 15, 2005 8:00 pm
The generic will work, but you cannot download or upload roms or maybe maps
Postby cboles » Sun Oct 16, 2005 8:27 pm
i'm going to start working on some more organized information pages... the new cable which is getting made as we speak has a software switchable programming voltage which allows it to behave as both a Subaru-specific reprogramming cable and a generic OBD cable.
Postby mr_yellow » Mon Oct 17, 2005 1:10 pm
Hey cool..
Thanks for the update.
I will try to wait patiently for the cable =)!
mr_yellow
Postby cboles » Mon Oct 17, 2005 2:12 pm
they should be ready to ship at the beginning of next week. you can order from the site now.
Postby west_minist » Mon Oct 17, 2005 4:43 pm
Colby,
Have you found out why the my cable fail?
My wrx cable is not working and behaving like the first cable.
I want to order v1.2, but I need to make sure what is causing this failure before I buy.
Is the new cable and same design as the first?
Please pm me a # I can call you, since the # in my email does not work.\
Thanks.
Postby cboles » Mon Oct 17, 2005 5:03 pm
I'm really at a loss as to why the cables do not work for you. The cable you returned to me seems to be working perfectly on 3 different computers. In fact, I am using it in an embedded datalogging PC in my rally car right now. I'm not sure if you are having an issue with the drivers, or if there is a problem with your USB host controller. The new 1.2 design still uses the same USB interface chip, so I can't imagine that things will improve much for you with that version.
west_minist wrote:Colby,
Thanks.
Postby west_minist » Mon Oct 17, 2005 6:23 pm
LOL.
I tried the wrx cable on two IBM T41 and my computer.
As you can see from the USB viewer, there is a problem, for which I opened a case with FTDI, which is closed now.
I have other USB devices that are still working, but unlike them, I keep the cable in the car.
I start the car and then plug in the cable.
Sometimes I turn of the car and then unplug.
I always keep the cable role up in the form it comes.
Well, I will try one last time.
I will purchase the new cable sometime soon, otherwise, I will try and see if I can get a AP one.
tactrix cable problems.jpg (92.65 KiB) Viewed 5823 times
Postby west_minist » Mon Oct 17, 2005 6:49 pm
I just purchase the new cable.
I will see how this goes.
The only thing I can think about is that my ECU is damaging the cable or excessive heat in the car.
Everthing single computer I use the cable with does not recognise it.
I have a JECS ECU.
