Installing 1.29 was a HUGE mistake! 1.29 doesnt work at all?
Postby disque71 » Sun Nov 12, 2006 11:19 am
I installed 1.29 for a vf39 install this weekend. Well, it wont reconize any interface! Have worked with ECUFlash many many time before, i know what I am doing. Installing 1.29 has also prevented me from going back to 1.28. When I uninstal 1.29 and try to reinstall 1.28, it dumps an error whenever I try to load the program?! WTF.
Anyone have this issue?
disque71
Postby Cabal » Sun Nov 12, 2006 11:52 am
Upgrade worked perfectly for me. Did you uninstall the old drivers from the 3 Add/Remove Programs entries and then reinstall them from the driver directory?
Cabal
Postby disque71 » Sun Nov 12, 2006 1:02 pm
uninstalled old drivers, reinstalled new ones as you said and it work
i guess with this release, you have to uninstall EVERYTHING. thanks
disque71
Postby wetroads » Tue Nov 14, 2006 5:37 pm
1.29 WAS working perfectly for me until this morning, it stopped recognising the cable and still won't. Tried uninstalling and reinstalling drivers, no good.
I can back out to the 1.28 drivers and get ecuexplorer working however a re-install of 1.28 won't run..!!
Damn!
wetroads
Postby wetroads » Tue Nov 14, 2006 10:12 pm
Update..
I have one Subaru cable working fine with 1.29, and two Mitsu cables no problems..
My other Subie cable is recognised as a Openport 1.20 ISO Interface however it won't install despite pointing it to the ECuflash drivers folder..
Has anyone else had this issue and how the hell do I fix it, I am over uninstalling and installing software...
wetroads
Postby disque71 » Wed Nov 15, 2006 4:26 pm
i had the same issue.
uninstall everything, old software and drivers
restart
reinstall 1.29
plug in cable
when prompted, point windows towards drivers folder(i think this happens twice[2drivers])
pray
flash
disque71
Postby wetroads » Wed Nov 15, 2006 7:45 pm
Tried that, I've even gone as far as installing a clean version of XP, still no joy.
It's bizarre, the system sees it as an Openport 1.2 cable but just won't install the drivers, and if I uninstall 1.29 and reinstall 1.28 then 1.28 won't run even on the brand new XP system.
I am trying to borrow another laptop in case it's something weird with mine, given that I've been running with no probs for months before this it's a bit frustrating..
wetroads
Postby wetroads » Fri Nov 17, 2006 1:08 am
Well after bucketloads of stuffing around it looks like I had two cables crap out on me at the same time which is why it was so hard to diagnose what was going on.
wetroads
Postby bmorrisj » Fri Nov 17, 2006 8:34 am
just in case, make sure the metal sheathing inside the cable, where it goes into the plastic housing, is not exposed... i had to take apart the housing a bit and tape up the cable...
bmorrisj
Postby wetroads » Fri Nov 17, 2006 4:03 pm
Yeah had that with my remaining cable, have checked one of the two non-working and it was okay, will have a look at the other.
wetroads
