Evo IX JDM GSR
Evo IX JDM GSR
Postby S54fan » Tue May 16, 2006 8:49 am
See attachment.
EVO9 GSR.hex
(512 KiB) Downloaded 1030 times
Postby S54fan » Tue May 16, 2006 12:13 pm
Fuel maps: 2ABD, 2BF5
http://john824.fotopic.net/p29315834.html
Load: 5FA8, 600C or 6AA8 - which one?
RPM: 5D1A, 5f80, 6DF4 or 71E6 - which one?
Can we write to Evo IX with 1.27 yet?
Postby S54fan » Tue May 16, 2006 2:14 pm
Ignition maps high octane then low octane
#1: 30C1, 325B
#2: 4437, 45D1
#3: 4905, 4A9F
A 7th ignition map at 55A9??
RPM zones: 657A (only 19 rather than 20 on the US Evo, and stops at 7000?)
Load zones: 600A
These need confirmation by someone brainier than I, this is just pattern recognition.
http://john824.fotopic.net/p29322643.html
http://john824.fotopic.net/p29322644.html
http://john824.fotopic.net/p29322645.html
Postby S54fan » Tue May 16, 2006 2:52 pm
MIVEC1: 5A33
RPM: 5FDC or 6ADA
Load: 5FA8 or 6AA8
http://john824.fotopic.net/p29323418.html
Postby S54fan » Wed May 17, 2006 12:25 am
Rev limiter: 118C
Boost cut and stationary rev limiter?
Postby S54fan » Wed May 17, 2006 5:41 am
There is a query over this ROM as to whether it is truncated a little early at the end compared with the ROMs posted with JM8859.
Here are extracts of the log:
[16:49:40.820] Version 1.26.636
[16:49:40.890] 9 memory models read.
[16:49:42.302] 65 ROM metadata models read.
[16:49:42.302] checksum module "subarudbw" loaded.
[16:49:42.312] flashing tool "wrx02" loaded.
[16:49:42.312] flashing tool "wrx04" loaded.
[16:49:42.312] flashing tool "sti04" loaded.
[16:49:42.312] flashing tool "sti05" loaded.
[16:49:42.312] flashing tool "evo" loaded.
[16:51:16.458] sending init sequence 1 (0001)
[16:51:17.489] got 0x05 response
[16:51:17.499] sending init sequence 2
[16:51:17.509] got 0x1B response
[16:51:17.519] sending init sequence 3
[16:51:17.930] entering bootloader
[16:51:17.960] sending kernel size (3460)
[16:51:17.990] sending kernel load address (0xFFFF9000)
[16:51:18.030] uploading kernel
[16:51:18.601] verifying kernel checksum response
[16:51:18.621] kernel valid
[16:51:18.651] sending init sequence 2a
[16:51:18.671] got 0x1C response
[16:51:18.681] sending init sequence 4
[16:51:18.821] Dumping ECU memory...
[16:51:18.841] kernel read area: addr: 000000 len: 0400
[16:51:19.141] kernel rsp page: 000000
[16:51:19.152] kernel read addr: 000000 len: 20
[16:51:19.162] kernel read addr: 000020 len: 20
[16:51:19.172] kernel read addr: 000040 len: 20
[16:51:19.172] kernel read addr: 000060 len: 20
[16:51:19.172] kernel read addr: 000080 len: 20
[16:51:19.172] kernel read addr: 0000A0 len: 20
[16:51:19.172] kernel read addr: 0000C0 len: 20
[16:51:19.172] kernel read addr: 0000E0 len: 20
[16:51:19.172] kernel read addr: 000100 len: 20
[16:51:19.172] kernel read addr: 000120 len: 20
[16:51:19.172] kernel read addr: 000140 len: 20
[16:51:19.172] kernel read addr: 000160 len: 20
[16:51:19.172] kernel read addr: 000180 len: 20
[16:51:19.172] kernel read addr: 0001A0 len: 20
[16:51:19.172] kernel read addr: 0001C0 len: 20
[16:51:19.172] kernel read addr: 0001E0 len: 20
[16:51:19.172] kernel read addr: 000200 len: 20
[16:51:19.172] kernel read addr: 000220 len: 20
[16:51:19.172] kernel read addr: 000240 len: 20
[16:51:19.242] kernel read addr: 000260 len: 20
[16:51:19.242] kernel read addr: 000280 len: 20
[16:51:19.242] kernel read addr: 0002A0 len: 20
[16:51:19.242] kernel read addr: 0002C0 len: 20
[16:51:19.242] kernel read addr: 0002E0 len: 20
[16:51:19.242] kernel read addr: 000300 len: 20
[16:51:19.242] kernel read addr: 000320 len: 20
[16:51:19.242] kernel read addr: 000340 len: 20
[16:51:19.242] kernel read addr: 000360 len: 20
[16:51:19.242] kernel read addr: 000380 len: 20
[16:51:19.242] kernel read addr: 0003A0 len: 20
[16:51:19.242] kernel read addr: 0003C0 len: 20
[16:51:19.242] kernel read addr: 0003E0 len: 20
[16:51:19.242] kernel rsp end
[16:51:19.242] kernel read area: addr: 000400 len: 0400
[16:51:19.552] kernel rsp page: 000000
[16:51:19.552] kernel read addr: 000400 len: 20
[16:51:19.552] kernel read addr: 000420 len: 20
[16:51:19.552] kernel read addr: 000440 len: 20
[16:51:19.552] kernel read addr: 000460 len: 20
etc and it keeps going in &H400 steps with the same pattern right to 512K.
I've also read it a second time and got an identical file.
I used ECUflash 1.26. I had to install a few DLLs as I am using Win 2000 on my slow laptop.
I will also try 1.27.
Postby S54fan » Wed May 17, 2006 6:29 am
1.27 gives the same ROM image.
Postby S54fan » Wed May 17, 2006 7:06 am
Boost cut in absolute pressure - estimated of course from the MAF sensor, so like engine load I think.
&H2D50 for boost limit table I think.
http://john824.fotopic.net/p29340319.html
I've chopped off the low rev stuff on the 9s, but it seems to be 1.55 bar tapering to 1.35 bar. On the 8 it is 1.45 tapering to 1.25 bar. Also the 9GSR seems to allow a bit higher boost up top compared with the 9US if I am correct.
Wastegate max values are all 100% as other ROMS, four possible candidates at 38AC, 38D8, 38EE, 391A.
Postby S54fan » Wed May 17, 2006 8:17 am
Boost targets - seem to be bar relative, top left are the three for 9GSR, top right is 9US, bottom is 8US, but the targets seem higher for the 8 than the 9, unrealistically so.
http://john824.fotopic.net/p29342317.html
Again, I have a 4th table which looks similar.
Addresses: 3946, 395C, 3972, 3988 with the RPM axis at 62B6.
Postby turbocharged » Wed May 17, 2006 8:48 am
Thanks for the efforts! :D
turbocharged
Postby DarkECU » Fri May 19, 2006 2:02 pm
<ecu_struct id="8857-08" type="JM8857-08 -> 1860A501 EVO 9 JDM GSR" include="">
<map name="2ABD -> Fuel Map High Octane" type="3" active="1" help="The coolant temperature that must be exceeded for closed loop fuelling operation." >
<cols count="20" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#5FA8" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#5F80" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] * 128)" offset="#2ABD" power="1" caption="Fuel Map Val (AFR)" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="2BF5 -> Fuel Map Low Octane" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] * 128)" offset="#2BF5" power="1" caption="Fuel Map Val (AFR)" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="30C1 -> Ignition Map High Octane #1" type="3" active="1" help="Asynchronous injection will not operate at below this amount of throttle movement." >
<cols count="21" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#600A" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="19" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#5FDA" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#30C1" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="325B -> Ignition Map Low Octane #1" type="3" active="1" help="Maximum asynchronous injection pulse width." >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#325B" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Fuel Map High Octane" type="3" active="0" help="" >
<cols count="18" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] * 128)" offset="#0" power="1" caption="Fuel Map Val (AFR)" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Fuel Map Low Octane" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map High Octane" type="3" active="0" help="Nominal injector flow scaling. Scaling assumes standard injectors are 540cc. If measuring injector flow, test should measure standard injectors as 540cc, then tested scaling will be correct." >
<cols count="19" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="19" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Ignition Map Low Octane" type="3" active="0" help="Engine Rev Limit" >
</map>
<map name="0 -> Ignition Map High Octane" type="3" active="0" help="Vehicle speed at which speed limiter disengages allowing normal driving." >
<rows count="20" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
</map>
<map name="0 -> Ignition Map Low Octane" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map High Octane #1" type="3" active="0" help="Asynchronous injection compensation used briefly after engine startup." >
<cols count="21" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
</map>
<map name="0 -> Ignition Map Low Octane #1" type="3" active="0" help="" >
</map>
<map name="5A33 -> VVT (Variable Valve Timing) Map" type="3" active="1" help="" >
<cols count="20" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#6AA8" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#6ADA" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#5A33" power="1" caption="VVT Angle (Degree)" desc="VVT Angle (Degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="4437 -> Ignition Map High Octane #2" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#4437" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="45D1 -> Ignition Map Low Octane #2" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#45D1" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="4905 -> Ignition Map High Octane #3" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#4905" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="4A9F -> Ignition Map Low Octane #3" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#4A9F" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="55A9 -> Ignition Map High Octane #4" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#55A9" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="True" reverse_bytes="True" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Ignition Map High Octane #2" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map Low Octane #2" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map High Octane #3" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map Low Octane #3" type="3" active="0" help="" >
</map>
<map name="0 -> Ignition Map High Octane #4" type="3" active="0" help="" >
</map>
<map name="0 -> Belch Map" type="3" active="0" help="" >
<cols count="5" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="17" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Cough Map 1" type="3" active="0" help="" >
<cols count="17" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="24" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> Squit Map" type="3" active="0" help="" >
<cols count="14" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="30" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> Flob Map" type="3" active="0" help="" >
<rows count="28" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> Cough Map 2" type="3" active="0" help="" >
</map>
<map name="0 -> Splutter Map" type="3" active="0" help="" >
<cols count="26" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="15" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> Wheeze Map" type="3" active="0" help="" >
<cols count="25" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="2D38 -> TFCNEH3_MA" type="3" active="1" help="" >
<cols count="3" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#2D38" power="1" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="33F5 -> Advance DWRT (21*19) #1" type="3" active="1" help="Maximum integral value." >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#33F5" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="476B -> Advance DWRT (21*19) #2" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#476B" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="4C39 -> Advance DWRT (21*19) #3" type="3" active="1" help="" >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#4C39" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Advance DWRT (19*19)" type="3" active="0" help="Vehicle speed at which speed limiter engages to reduce vehicle speed." >
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Ignition Degrees (degree)" desc="Ignition Degrees (degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> Advance DWRT (19*20)" type="3" active="0" help="Time period for which boost limit must be exceeded before fuel cut is activated." >
</map>
<map name="0 -> Advance DWRT (21*19) #1" type="3" active="0" help="" >
</map>
<map name="0 -> Advance DWRT (21*19) #2" type="3" active="0" help="" >
</map>
<map name="0 -> Advance DWRT (21*19) #3" type="3" active="0" help="" >
</map>
<map name="0 -> TFLICS" type="3" active="0" help="" >
<cols count="27" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="8" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Steps (Steps)" desc="Steps (Steps)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> TIEL" type="3" active="0" help="" >
<cols count="11" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="Current (Amps)" desc="Current (Amps)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="0 -> TBMTHWVA1" type="3" active="0" help="" >
<cols count="7" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
<rows count="10" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="Unknown Param ()" desc="Unknown Param ()" signed="False" reverse_bytes="False" />
</map>
<map name="0 -> TBMTHA2" type="3" active="0" help="" >
</map>
<map name="0 -> VVT (Variable Valve Timing) Map" type="3" active="0" help="" >
<cols count="20" format="%.f" func_2val="[value]/32*10" func_val2="[value]/10*32" offset="#0" power="2" caption="Engine Load (%)" desc="Engine Load (%)" signed="False" reverse_bytes="True" />
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="Engine Speed (RPM)" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True" />
<data order="RC" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="1" caption="VVT Angle (Degree)" desc="VVT Angle (Degree)" signed="False" reverse_bytes="False" color_dir="0" inc="20" incb="170" inc_dir="1" />
</map>
<map name="2D50 -> Boost Limit" type="2" active="1" help="Vehicle speed at which speed limiter disengages allowing normal driving." >
<rows count="9" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#66F4" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#2d50" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="38AC -> Max Wastegate Duty - A" type="2" active="1" help="" >
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#62B6" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#38ac" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="38C2 -> Max Wastegate Duty - B" type="2" active="1" help="" >
<data offset="#38c2" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="38D8 -> Max Wastegate Duty - C" type="2" active="1" help="" >
<data offset="#38d8" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="38EE -> Max Wastegate Duty - D" type="2" active="1" help="" >
<data offset="#38ee" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3904 -> Max Wastegate Duty - E" type="2" active="1" help="" >
<data offset="#3904" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="391A -> Max Wastegate Duty - F" type="2" active="1" help="" >
<data offset="#391a" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3930 -> Max Wastegate Duty - G" type="2" active="1" help="" >
<data offset="#3930" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Wastegate Duty (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3946 -> Boost Desired Engine Load - A" type="2" active="1" help="" >
<data offset="#3946" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="395C -> Boost Desired Engine Load - B" type="2" active="1" help="" >
<data offset="#395c" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3972 -> Boost Desired Engine Load - C" type="2" active="1" help="" >
<data offset="#3972" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3988 -> Boost Desired Engine Load - D" type="2" active="1" help="" >
<data offset="#3988" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3351 -> AFM" type="2" active="1" help="" >
<rows count="116506" format="" func_2val="" func_val2="ngine load to be achieved by regulation of turbo boost pressure. Add 1D value 'Boost Control - Desired Engine Load Offset' to determine desired load. 200% load is approx 1.2bar of boost." offset="#66AE" power="2" caption="" desc=" ()" signed="False" reverse_bytes="False"/>
<data offset="#3351" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Boost Desired Engine Load - E" type="2" active="0" help="" >
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2F50 -> Acceleration Enrichment" type="2" active="1" help="Asynchronous injection compensation used briefly after engine startup." >
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#5D1A" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#2f50" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Adjustment (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3894 -> Turbo Dynamics" type="2" active="1" help="" >
<rows count="17" format="%.1f" func_2val="[value]/8192" func_val2="[value]*8192" offset="#62E0" power="2" caption="%" desc="Boost Error (%)" signed="False" reverse_bytes="True"/>
<data offset="#3894" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Turbo Dynamics (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2D60 -> Open Loop Load #1" type="2" active="1" help="" >
<rows count="16" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#5C8C" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#2d60" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2D76 -> Open Loop Load #2" type="2" active="1" help="Time period for which boost limit must be exceeded before fuel cut is activated." >
<data offset="#2d76" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2D92 -> Open Loop Throttle Low Load" type="2" active="1" help="The coolant temperature that must be exceeded for closed loop fuelling operation." >
<data offset="#2d92" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="V" color_dir="0" desc="Voltage (V)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2DA8 -> Open Loop Throttle High Load" type="2" active="1" help="" >
<data offset="#2da8" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="V" color_dir="0" desc="Voltage (V)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2EAC -> Injector battery voltage compensation" type="2" active="1" help="Maximum asynchronous injection pulse width." >
<rows count="7" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#5EE8" power="2" caption="V" desc="Battery Voltage (V)" signed="False" reverse_bytes="False"/>
<data offset="#2eac" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="ms" color_dir="0" desc="Lag Time (ms)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="367E -> Desired Idle RPM - Neutral" type="2" active="1" help="" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#6182" power="2" caption="C " desc="Coolant Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#367e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="RPM" color_dir="0" desc="Engine Speed (RPM)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3692 -> Desired ISCV initial step position with AC off - Neutral" type="2" active="1" help="" >
<data offset="#3692" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="36A5 -> Desired ISCV initial step position with AC off - Drive" type="2" active="1" help="" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="C " desc="Coolant Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#36a5" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="36BA -> Desired ISCV initial step position with AC on - Neutral" type="2" active="1" help="" >
<data offset="#36ba" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="36C8 -> Desired ISCV initial step position with AC on - Drive" type="2" active="1" help="" >
<data offset="#36c8" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="Steps" color_dir="0" desc="ISCV Steps (Steps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Desired Idle RPM - Drive" type="2" active="0" help="" >
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="RPM" color_dir="0" desc="Engine Speed (RPM)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2A06 -> AFM speed ?" type="2" active="1" help="" >
<rows count="21" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#5E98" power="2" caption="Hz" desc="Frequency (Hz)" signed="False" reverse_bytes="False"/>
<data offset="#2a06" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2A22 -> AFM Frequency compensation" type="2" active="1" help="" >
<data offset="#2a22" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Adjustment (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2AA2 -> AFM Air Temperature compensation" type="2" active="1" help="" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#61D2" power="2" caption="C " desc="Air Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#2aa2" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Adjustment (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2A7C -> AFM Pulses Per Second ?" type="2" active="1" help="Nominal injector flow scaling. Scaling assumes standard injectors are 540cc. If measuring injector flow, test should measure standard injectors as 540cc, then tested scaling will be correct." >
<rows count="17" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="" desc="Unknown Param ()" signed="False" reverse_bytes="False"/>
<data offset="#2a7c" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="pps" color_dir="0" desc="Pulses per second (pps)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2A94 -> AFM Water Temperature compensation" type="2" active="1" help="Engine Rev Limit" >
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#60BC" power="2" caption="C " desc="Coolant Temperature (C )" signed="False" reverse_bytes="False"/>
<data offset="#2a94" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Adjustment (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2D30 -> Overrun Fuel Cut-off RPM vs Coolant Temp" type="2" active="1" help="Vehicle speed at which speed limiter engages to reduce vehicle speed." >
<data offset="#2d30" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="RPM" color_dir="0" desc="Engine Speed (RPM)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2F66 -> A/F Correction Coeff for water temp" type="2" active="1" help="" >
<data offset="#2f66" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Percent (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2F8E -> Asynchronous Injection base pulse width against throttle angle delta" type="2" active="1" help="" >
<rows count="10" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#5C6E" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#2f8e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2F9E -> Asynchronous Injection limitation TPS voltage" type="2" active="1" help="" >
<data offset="#2f9e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2FAE -> Asynchronous Injection coolant temp compensation coefficient" type="2" active="1" help="" >
<data offset="#2fae" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="2FBC -> Asynchronous Injection compensation coefficient against Ne" type="2" active="1" help="" >
<rows count="15" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#2fbc" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3066 -> Lean Spool: Trailing time (rich side)" type="2" active="1" help="" >
<rows count="14" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#5F42" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3066" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="s" color_dir="0" desc="Time Period (s)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="307A -> Lean Spool: Trailing time (lean side)" type="2" active="1" help="" >
<data offset="#307a" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="s" color_dir="0" desc="Time Period (s)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="308E -> Lean Spool: Engine Load Threshold" type="2" active="1" help="" >
<data offset="#308e" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="30A2 -> Lean Spool: AFR Adjustment" type="2" active="1" help="" >
<rows count="7" format="%.1f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] / 128)" offset="#5F68" power="2" caption="AFR" desc="Fuel Map Val (AFR)" signed="False" reverse_bytes="True"/>
<data offset="#30a2" format="%.2f" func_2val="14.7/([value] / 128)" func_val2="(14.7/[value] * 128)" power="1" caption="AFR" color_dir="0" desc="Fuel Map Val (AFR)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="362C -> Knock control judgement boost map" type="2" active="1" help="" >
<rows count="9" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="" desc="Unknown Param ()" signed="False" reverse_bytes="False"/>
<data offset="#362c" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="363C -> Knock learning function area boost map" type="2" active="1" help="" >
<data offset="#363c" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3670 -> Knock learning function initialise value" type="2" active="1" help="" >
<data offset="#3670" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3FE0 -> Air Inject Time" type="2" active="1" help="Engine load value that must be added to desired engine load 2D maps to determine actual desired boost profile." >
<rows count="9" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#66D8" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3fe0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="msec" color_dir="0" desc="Air Inject Time (msec)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> ?????????" type="2" active="0" help="Asynchronous injection will not operate at below this amount of throttle movement." >
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="" color_dir="0" desc="Unknown Param ()" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Inj. Time Compensation" type="2" active="0" help="Maximum integral value." >
<rows count="36" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0" power="2" caption="" desc="Unknown Param ()" signed="False" reverse_bytes="False"/>
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="usec" color_dir="0" desc="Fuel Inj Time Comp (usec)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Lo Mid Hi Off Fan Control" type="2" active="0" help="" >
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="km/h" color_dir="0" desc="Vehicle Speed (km/h)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="0 -> Lo Mid Hi On Fan Control" type="2" active="0" help="" >
</map>
<data offset="#0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="degree" color_dir="0" desc="Temperature (degree)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
</map>
<map name="36D6 -> ISC Steps" type="2" active="1" help="" >
<rows count="8" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#36d6" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="36E4 -> ISC D/P initial from Throttle Voltage AC Off - Neutral" type="2" active="1" help="" >
<rows count="7" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#36e4" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="36F2 -> ISC D/P initial from Throttle Voltage AC Off - Drive" type="2" active="1" help="" >
<data offset="#36f2" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3745 -> ISC desired position high altitude compensation" type="2" active="1" help="" >
<rows count="5" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3745" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3756 -> ISC Error Dynamics - Neutral" type="2" active="1" help="" >
<rows count="9" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="RPM" desc="Engine Speed (RPM)" signed="False" reverse_bytes="True"/>
<data offset="#3756" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="3766 -> ISC Error Dynamics - Drive" type="2" active="1" help="" >
<data offset="#3766" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="%" color_dir="0" desc="Boost Limit Engine Load (%)" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="False"/>
</map>
<map name="39E8 -> Fan Control - 1" type="2" active="1" help="" >
<rows count="12" format="%.f" func_2val="[value]/128*500" func_val2="[value]/500*128" offset="#0" power="2" caption="R
DarkECU
Postby S54fan » Fri May 19, 2006 2:41 pm
DarkECU that is simply fantastic, you must have put lots of hours into these! Thanks!
Have the files you've posted been truncated though? I'm trying to work out how to use the file as it is, if I paste it and save it as XML I get "unexpected end of file". Are you able to attach the actual XML file you've made?
Postby DarkECU » Fri May 19, 2006 3:30 pm
Ok
No problem....
8857-08.txt
(109.29 KiB) Downloaded 996 times
DarkECU
Postby S54fan » Sat May 20, 2006 1:36 am
Thanks again. Opening up these maps in ECUedit is great. How on earth did you find all those? Disassembly? Any comments on how these maps work? Does it get quite a lot easier once you've done on JM885x that all the rest have a few offsets from there?
Postby turbocharged » Sat May 20, 2006 3:01 am
S54fan wrote:Thanks again. Opening up these maps in ECUedit is great. How on earth did you find all those? Disassembly? Any comments on how these maps work? Does it get quite a lot easier once you've done on JM885x that all the rest have a few offsets from there?
Ermm...how do I use what DarkECU posted to read the JDM Evo9 ROM?
turbocharged
