MattS00 wrote:Your rom ID is 21800023. It is located at address 1021a. I am not capable of dissassembling roms, so I just took an existing .xml for a 00 v6 eclipse. Looked up your rom ID and changed the rom ID in the .xml. The immobilizer code has not been found yet. Do you have a V6 eclipse?
acamus wrote:It is because not many H8 ECU's had immo.
I believe the address is 2fece, unfortunately I cannot test it as I am not in possession of one.
meclipsegt please report back if it helped.
backup solution is to change periphery bits 0x52DE -> 0x52D6 in 96720009, but I would try value at 2fece first.
