Evo6 EM2557-00 - RA 420996 EVO 6 Ralliart
Postby AIK » Wed Nov 26, 2008 3:52 am
ECU Group = EVO 5/6 Ralliart Group.
Is it possible to read this ROM by EcuFlash, or I need to replace Evo7 or Evo8 Ecu to this car only?
Thanks for the help.
AIK
Postby todd-w » Wed Nov 26, 2008 1:44 pm
7 ecu and use 90550001 ra rom ,you will need to swap a few pins what car ?
todd-w
Postby AIK » Thu Nov 27, 2008 2:09 am
todd-w wrote:you will need to swap a few pins what car ?
Yes, I know it. I Have pin-cards for Evo7 and Evo6. The car is Evo6 (EM2557-00 - RA 420996 EVO 6 Ralliart ECU Group = EVO 5/6 Ralliart Group). Thanks you.
AIK
Postby AIK » Fri Nov 28, 2008 12:38 pm
I tried tod with several Evo6 and several 7 Ecu. Always EcuFlesh don't see Ecu. But my openport 1.3 U fave 2 sockets, all cars have 1 (trapezoid) socket only. The problem can in it?
AIK
Postby todd-w » Sat Nov 29, 2008 12:21 pm
yes all evos from evo5 up have the second white initialization socket ,, its usually taped to the loom just above the obd socket . il look for a pic for you
todd-w
Postby todd-w » Sat Nov 29, 2008 12:30 pm
white socket in middle of pic
todd-w
Postby AIK » Sun Nov 30, 2008 12:09 pm
todd-w
Thanks you.
AIK
Postby todd-w » Sun Nov 30, 2008 1:02 pm
8) let me know how you get on.
todd-w
Postby AIK » Mon Dec 01, 2008 12:15 pm
OK, If I receive positive results - I'll write how.
AIK
Postby AIK » Mon Dec 08, 2008 2:34 pm
1. Connect 62 from the Ecu to 7 to OBD (Having cut off both)
2. Swap pins 8 and 22
3. Swap pins 32 and 34
4. Disconnect pin 87
5. Disconnect pin 20
DON'T
Connect 34 from the ECU to 20 on the vehicle harness
Don't
Connect 32 from the ECU to 21 on the vehicle harness
because we have installed block of management of the engine fan (from Evo7) to 21 pin
6. Switched off immo.
There really two plugs for a cable. Simply the second should look.
AIK
Postby todd-w » Mon Dec 08, 2008 3:10 pm
why did you have to do pin62 to obd
todd-w
Postby AIK » Tue Dec 09, 2008 4:17 am
todd-w wrote:why did you have to do pin62 to obd
When i do points 2-6, i has got the engine, but i haven't possibility to read
new Evo7 Ecu in Evo6 (by my Openport 1.3 U cable). When i do 1 point, i have seen and reflash it.
AIK
