Airtrek Turbo Speed Cut removal
Postby Tunedair » Tue Jan 15, 2008 11:27 pm
Hi All,
I need help in removing my speed cut. I've tried changing the values of the speed limiter to 510 510 but it doesn't work. I must've missed something.
I've read my ECU by using the E9 kernel and manage to grab my ecu data out. Do I need to change anything else to get the removal of speed limiter working?
Tunedair
Postby Tuky » Wed Jan 16, 2008 2:25 am
Bro,
Post your hex file, do a new read from the ecu.
Cheers
Tuky
Postby Tunedair » Thu Jan 17, 2008 4:05 am
tuky,
I don't have a hex file. I only have the bin file. Please see attached.
AirtrekBWN.bin
(512 KiB) Downloaded 710 times
Tunedair
Postby Tuky » Thu Jan 17, 2008 4:19 am
bro, the file you attached it does not have the value 510 510.
I've sent you the updated file thru PM. Let me know how it goes.
Cheers
Tuky
Tuky
Postby Tunedair » Thu Jan 17, 2008 6:00 am
Thanks.
Tunedair
Postby Guest » Sun Jan 27, 2008 11:42 am
Any idea how to link the TAC-OpenPort1.3U to the ECU to reflash the airtrek turbo ECU?
i bought the cable, but can't find the connector which WRX have it next to the OBD2 port under steeringwheel.
thanks
Guest
