by bigleadfoot » Sun Nov 26, 2006 3:28 am
Hy!
May I join in here as I have a little problem reading the rom of my IXer.
I connected the cable (the OBD plug and the white one), switched on the ignition and started ecuflash. When I try to read the rom, the dialog for selecting the car pops up and when I select "2006 Evo 9" and hit "Read" I get the following result (see attached picture). I've tried a couple of different approaches, but nothing really works.
What I tried without success:
- Started ecuflash, hit read rom, connected the obd and white plug, ignitoon on and then hit "Ok".
- Cable connected to car (both plugs), ignition on, started ecuflash, hit read rom and then hit "Ok".
- Cable connected to car (both plugs), started ecuflash, hit read rom, ignition on and then hit "Ok".
Then I ran out of ideas.
When I start up evoscan 0.97 it works perfect, just ecuflash refuses the cooperation.
Car is a 2006 EVO 9 German model.
Any help would be appreciated.
Thanks.
Alex
- Attachments
- ecf1.png (35.75 KiB) Viewed 7126 times
