EVO5 GSR Rom - 22580006
Postby nocturnal walt » Tue Jul 29, 2008 1:32 am
Here is a stock 1998 EVO5 GSR Rom I read with ECUFlash. I have a partially completed XML file that I made for this. I'll post it once I have a bit more done.
22580006 EM2258 98EVO5GSR.bin
(128 KiB) Downloaded 772 times
nocturnal walt
Postby cossie1 » Wed Aug 06, 2008 9:08 am
Can you post up the xml you have so far please.
cossie1
Postby nocturnal walt » Tue Sep 09, 2008 1:32 am
Yeah sure, but there is still lots that needs to be finished. This seems to work for all EVO5s but the EVO6 roms I have seen are offset by a few bytes so need a different xml file.
Also, use my evo5 base or my xml will not work.
evo5base.xml
(9.9 KiB) Downloaded 694 times
22580006 unfinished.xml
(1.99 KiB) Downloaded 683 times
nocturnal walt
Postby cossie1 » Tue Sep 09, 2008 4:53 am
Some nice work there.
Just 1 thing i've picked up on.
Low Octane Fuel Map address is incorrect.
This is the correct address for it 119bd
With the evo 6 tables, there in similar locations, most just need 2 adding to the end of the address's.
So for low octane fuel map just change 119bd to 119bf and so on.
But I still can't find the scalings for the evo 6 roms :(
cossie1
Postby nocturnal walt » Wed Sep 10, 2008 12:42 am
Yeah, you're right. Good spotting. I did have the low octane fuel map address right in another editor I was using. But when I transfered all the data over into an xml I must have missed it out and used the high octane fuel map address for both.
I noticed that most stuff on the EVO6 was offset by two bytes, but I haven't really looked at these roms much. What scalings are you looking for in particular? I can probably find them the same way as I did for the EVO5.
nocturnal walt
Postby nocturnal walt » Wed Sep 10, 2008 2:46 am
I found the load/rpm scales for the fuel/ign tables on the 6. I also found a couple other things like boost error correction.
27370001 unfinished.xml
(2.14 KiB) Downloaded 654 times
nocturnal walt
Postby cossie1 » Wed Sep 10, 2008 4:19 am
Yeh I found most of the scalings last night when I was messing about.
Most evo 6 roms are offset by 82.
Here are my updated versions of your 2 def files.
I have found a couple of extra address's but some of them are not correct yet (I gave up at 5am).
Edited to update the files.
I think this is where I am going to get stuck now.
There are a few address's that I still can't get right, but hey there is alot more there than we have seen until now, so it's a good start :D
22580006.xml
(6.1 KiB) Downloaded 717 times
27370001.xml
(6.1 KiB) Downloaded 702 times
evo5base.xml
(20.17 KiB) Downloaded 705 times
cossie1
Postby nocturnal walt » Thu Sep 11, 2008 1:35 am
Nice work mate.
Like you said, there are a few things that don't look right, but lots that does look right and we're certainly making progress.
What addresses in particular are you still trying to get right?
nocturnal walt
Postby cossie1 » Thu Sep 11, 2008 3:10 am
nocturnal walt wrote:Nice work mate.
The main ones are, boost limit, min temp for full boost control, idle speed control steps, the temp scaling, and some of the rpm tables might be a little off too.
cossie1
Postby cossie1 » Thu Sep 18, 2008 4:02 am
Ok found the boost limit addy now.
11af8 for an evo 6 and 11af6 for an evo 5.
E5
Boost Limit 11af6
Rpm 2c7b4
9 Columns
E6
Boost Limt 11af8
Rpm 2c836
9 Columns
Also the address for the Barometric Pressure Compensation is:
E5
Table = 11847
Units = 2c6dc
Rpm = 2c71a
E6
Table = 11847
Units = 2c75e
Rpm = 2c79c
cossie1
Postby nocturnal walt » Sun Sep 28, 2008 1:56 am
nice work :)
nocturnal walt
Postby cossie1 » Sun Sep 28, 2008 2:11 am
Thanks.
I don't think there are any other tables we need to define, even if we could flash the roms back :lol:
cossie1
ecuflash 1.39 H8 flash?
Postby red^shark » Sun Oct 12, 2008 10:22 am
Does the new version of ecuflash enable the H8 flash?
Thoughts?
red
red^shark
Postby got boost? » Mon Oct 27, 2008 6:25 pm
cossie1 wrote:Ok found the boost limit addy now.
E5
Boost Limit 11af6
Rpm 2c7b4
9 Columns
E6
Boost Limt 11af8
Rpm 2c836
9 Columns
E5
Table = 11847
Units = 2c6dc
Rpm = 2c71a
E6
Table = 11847
Units = 2c75e
Rpm = 2c79c
Hi there,
cossie, that info is supossed to be added to the evo5base xml file??? if so, how??
thanks.
got boost?
Postby cossie1 » Tue Oct 28, 2008 1:57 am
no into the evo 5 rom xml and evo 6 rom xml, as the address's are different.
cossie1
