The format seems different, though, so not sure how to "fix" it.
twg wrote:The STI seems to have the same format, so give the following a try:
Search for code 0420 (I found it at address 0x455B8), enter it into the following formula:
(OBD2code_address-0x450CB)/0x14+0x45028
You get 0x45067, at this address, enter in a 0 (it is currently 1)... reflash, and report back to see if that worked...
[url][/url]Freon wrote:Hatchy, what model ECU do you have? AJ241? AJ242?
Post your rom file somewhere. You can attach it via the forum on a post, button is right above the"preview" and "submit" buttons.
If you have an AJ241 like I do, the P0420 CEL is right around 455B8, just like the picture I posted.
I haven't gotten around to revisiting this yet. I'll flash this change into my ECU again later this week. I just confirmed the flash I have now does not have value at 45067 set to "0," it is still "1." I got a P0420 a few days ago.
