A4SGD10C - 2002 WRX 5MT Stage 1 HWG
Postby ev8siv3 » Tue Mar 28, 2006 10:30 am
Here is a ROM dump from a 2002 Stage 1 WRX running the High Wastegate Map to achieve target boost of approximately 14.5psi. I am working on the ECU Definitions file to allow more editing but haven't finalized a solid definition file yet.
Attached are the 160k and 192k versions. Use at your own risk.
** Will repost Later **
ev8siv3
Re: A4SGD10C - 2002 WRX 5MT Stage 1 HWG
Postby silverpike » Fri Mar 31, 2006 5:50 pm
ev8siv3 wrote:Here is a ROM dump from a 2002 Stage 1 WRX running the High Wastegate Map to achieve target boost of approximately 14.5psi. I am working on the ECU Definitions file to allow more editing but haven't finalized a solid definition file yet.
This sounds interesting.
Can you tell me more about this map? Is it a custom tune? Did you tune it yourself? I thought that the WRX makes 14 PSI at redline already...
silverpike
Postby Houdini » Sun May 14, 2006 1:35 pm
Any reason going with 14.5 psi? TXS stage 1 is 16.1 psi peak.
4000 16.1
5500 15
6000 12.5
7000 12
Houdini
