04 WRX AP to OPENECU upgrade
Postby twiztidunreal » Mon Jul 16, 2007 12:50 pm
i am currently running a V1 AP with PDX custom tune maps on an 04 2.5 wrx, 18g 7cm, modded injectors, etc.
I recently got a tactrix cable and was wondering, if i needed my AP any more or if i could pass it on to someone needing a stage 2 or so..
I know u can make a rom of your current ecu with the cable then edit and re-upload.. but my question is, will my pdx AP map work if i made a rom of it, un-married my AP, changed a few of my cel's from my pdx map, then reloaded the Rom to the ecu via tactrix with AP unmarried?? is this possiable?
twiztidunreal
Postby veightkiller » Mon Aug 13, 2007 4:16 pm
the map arent going to work since they are save from a different file.
veightkiller
AP stage 1
Postby dougkmcse » Mon Mar 24, 2008 5:57 pm
I have the same ? Can i edit the cobb map or do i have to unmarrie it and the get a stage 1 map from here. Then upload it ro the car.
dougkmcse
Postby Freon » Wed Mar 26, 2008 4:13 pm
You're best off just unmarrying and getting your own good tune from scratch. Find a local openecu tuner. Selling your AP will likely pay for the tune or more.
ap
Postby dougkmcse » Thu Apr 24, 2008 5:51 pm
I was able to read ap stage 1 93. After reading it i unmarried it from the ecu. The map it left behind was messed up. I was able to use ecuflash to install a good map. I then remarried the ap. Then i unmarried the ap. This time the map was good except they put a AT map on my MT wrx. No i have not used the ap map. The only thing i have used it for is to compare to the map i am working on. I am working with the free stage 1 map. It is nice to have some refrences between the stock map and the ap map.
dougkmcse
