Pulling the ROM on JDM LGT 2.0 SpecB 6MT
Postby zigzagzok » Wed Oct 11, 2006 2:03 am
I understd that we would have to use ECUFLash to download the ROM;
To download a copy of the ROM i wld connect the greeen connector
but when i short the connectors, my radiator fans start cycling and the relays click click click;
on hearing this i disconnected the plugs
am driving a JDM LGT 2.0 SpecB 6MT -with SI Drive
the ecu is below
would appreciate any advice
zigzagzok
Postby west_minist » Wed Oct 11, 2006 2:31 am
Do you have a green connector under the steering column?
When you connect it, you will hear that.
Start the ecufash and prepare it for down load.
push in the clutch and turn the key on. As soon as you do that, press ok.
Postby LGT+WRX » Wed Oct 11, 2006 5:15 pm
^ +1.
For the USDM 2.5GT (turbocharged, BL/BP) models, the fan-cycling/relay-clicking after the green connectors have been shorted is normal, and will cease eventually (when the ECU is connected).
I am unable to confirm, however, if the same holds true for JDM vehicles.
LGT+WRX
Postby radsdau » Wed Oct 11, 2006 10:38 pm
west_minist wrote:push in the clutch and turn the key on. As soon as you do that, press ok.
What does pushing in the clutch do? (other than the obvious mechanical stuff... 8) )
Postby Freon » Thu Oct 12, 2006 12:00 am
The green connector is the "test" or "diagnostics mode" connector. That's why your fans start to cycle. The system is doing some sort of self test.
The trick is clicking "ok" on Ecuflash moments after you turn the key. This is just how it works.
I don't think you need to press the clutch. ??? Not that it would hurt.
Postby zigzagzok » Thu Oct 12, 2006 6:45 pm
hi all thks for the info ! :) will try out this weekend
need to push in the clutch to start the car - think there is another switch..
zigzagzok
Postby zigzagzok » Sun Oct 15, 2006 12:05 am
Freon wrote:The green connector is the "test" or "diagnostics mode" connector. That's why your fans start to cycle. The system is doing some sort of self test.
hi all need ur help again :(
the software ECUFLASH - with the latest version downloaded 2/10/06 it started fine - detected the Openport 1.3 Mitsubishi cable - shown on the right corner of the window
then i followed the procedure below to try to pull the rom
http://forums.openecu.org/viewtopic.php?t=904
twice with the clutch in
twice with the clutch out
keep getting this error msg - any idea?
much thanks!!
[00:08:46.757] Version 1.29.906
[00:08:46.767] 8 memory models read.
[00:08:49.661] 140 ROM metadata models read.
[00:08:49.661] checksum module "subarudbw" loaded.
[00:08:49.661] flashing tool "wrx02" loaded.
[00:08:49.661] flashing tool "wrx04" loaded.
[00:08:49.661] flashing tool "sti04" loaded.
[00:08:49.661] flashing tool "sti05" loaded.
[00:08:49.661] flashing tool "mitsukernel" loaded.
[00:08:49.661] flashing tool "mitsukernelocp" loaded.
[00:08:49.661] flashing tool "mitsubootloader" loaded.
[00:10:52.658] ssm2_init
[00:10:52.898] ssm2_init
[00:10:52.908] ssm2_init
[00:10:52.928] ssm2_init
[00:10:52.948] ssm2_init
[00:10:52.958] ssm2_init
[00:10:52.978] ssm2_init
[00:10:52.998] ssm2_init
[00:10:53.008] ssm2_init
[00:10:53.029] ssm2_init
[00:10:53.219] kernel get version
[00:10:53.539] validating denso kernel ram area addr: FFFF0000 len: 0008
[00:12:23.328] ssm2_init
[00:12:23.559] ssm2_init
[00:12:23.569] ssm2_init
[00:12:23.589] ssm2_init
[00:12:23.609] ssm2_init
[00:12:23.629] ssm2_init
[00:12:23.639] ssm2_init
[00:12:23.659] ssm2_init
[00:12:23.679] ssm2_init
[00:12:23.699] ssm2_init
[00:12:23.879] kernel get version
[00:12:24.410] validating denso kernel ram area addr: FFFF0000 len: 0008
[00:13:24.807] ssm2_init
[00:13:25.037] ssm2_init
[00:13:25.047] ssm2_init
[00:13:25.067] ssm2_init
[00:13:25.087] ssm2_init
[00:13:25.097] ssm2_init
[00:13:25.117] ssm2_init
[00:13:25.137] ssm2_init
[00:13:25.147] ssm2_init
[00:13:25.177] ssm2_init
[00:13:25.368] kernel get version
[00:13:25.688] validating denso kernel ram area addr: FFFF0000 len: 0008
[00:15:29.035] ssm2_init
[00:15:29.266] ssm2_init
[00:15:29.286] ssm2_init
[00:15:29.306] ssm2_init
[00:15:29.316] ssm2_init
[00:15:29.336] ssm2_init
[00:15:29.346] ssm2_init
[00:15:29.366] ssm2_init
[00:15:29.386] ssm2_init
[00:15:29.566] kernel get version
[00:15:30.097] validating denso kernel ram area addr: FFFF0000 len: 0008
zigzagzok
Postby bmorrisj » Tue Oct 17, 2006 9:05 am
either you are waiting too long or your ecu is a brick.... the car still runs normally right....
when i use ecu flash...
1. connect green plugs
2. ready ecuflash for flashing
a. select map
b. click the flash button
c. now im ready with an 'OK' prompt
3. turn the key to ignition then immediately click ok
4. flash done, turn off the key
bmorrisj
Postby zigzagzok » Wed Oct 18, 2006 7:39 pm
bmorrisj wrote:either you are waiting too long or your ecu is a brick.... the car still runs normally right....
a. select map
thats wat i do; green plugs connected
left hand turn ignition key to "on"
right hand click "ok" button.... almost simultaneously
wonder becoz the ecu is japanese - if it will make any difference?....
zigzagzok
Postby zigzagzok » Sun Nov 19, 2006 10:54 pm
hi all
i have done the following
still no luck to pull down the rom :(
did the installation as follows below
picture of the green connector
and the openport connector
ECUFLASH log
[00:12:05.623] Version 1.29.906
[00:12:05.623] 8 memory models read.
[00:12:06.835] 140 ROM metadata models read.
[00:12:06.835] checksum module "subarudbw" loaded.
[00:12:06.835] flashing tool "wrx02" loaded.
[00:12:06.835] flashing tool "wrx04" loaded.
[00:12:06.835] flashing tool "sti04" loaded.
[00:12:06.835] flashing tool "sti05" loaded.
[00:12:06.835] flashing tool "mitsukernel" loaded.
[00:12:06.835] flashing tool "mitsukernelocp" loaded.
[00:12:06.835] flashing tool "mitsubootloader" loaded.
[00:12:22.307] ssm2_init
[00:12:22.547] ssm2_init
[00:12:22.567] ssm2_init
[00:12:22.597] ssm2_init
[00:12:22.828] ssm2_init
[00:12:22.838] ssm2_init
[00:12:22.858] ssm2_init
[00:12:22.878] ssm2_init
[00:12:22.888] ssm2_init
[00:12:23.078] kernel get version
[00:12:23.599] validating denso kernel ram area addr: FFFF0000 len: 0008
[00:12:50.427] ssm2_init
[00:12:50.668] ssm2_init
[00:12:50.688] ssm2_init
[00:12:50.708] ssm2_init
[00:12:50.718] ssm2_init
[00:12:50.738] ssm2_init
[00:12:50.748] ssm2_init
[00:12:50.768] ssm2_init
[00:12:50.788] ssm2_init
[00:12:50.968] kernel get version
[00:12:51.499] validating denso kernel ram area addr: FFFF6000 len: 0008
[00:14:44.501] ssm2_init
[00:14:44.732] ssm2_init
[00:14:44.752] ssm2_init
[00:14:44.762] ssm2_init
[00:14:44.782] ssm2_init
[00:14:44.802] ssm2_init
[00:14:44.812] ssm2_init
[00:14:44.832] ssm2_init
[00:14:44.842] ssm2_init
[00:14:45.022] kernel get version
[00:14:45.553] validating denso kernel ram area addr: FFFF0000 len: 0008
[00:15:49.134] ssm2_init
[00:15:49.365] ssm2_init
[00:15:49.375] ssm2_init
[00:15:49.395] ssm2_init
[00:15:49.415] ssm2_init
[00:15:49.435] ssm2_init
[00:15:49.455] ssm2_init
[00:15:49.465] ssm2_init
[00:15:49.485] ssm2_init
[00:15:49.495] ssm2_init
[00:15:49.685] kernel get version
[00:15:50.216] validating denso kernel ram area addr: FFFF0000 len: 0008
[00:16:16.033] ssm2_init
[00:16:16.263] ssm2_init
[00:16:16.283] ssm2_init
[00:16:16.293] ssm2_init
[00:16:16.313] ssm2_init
[00:16:16.323] ssm2_init
[00:16:16.343] ssm2_init
[00:16:16.363] ssm2_init
[00:16:16.534] kernel get version
[00:16:17.074] validating denso kernel ram area addr: FFFF0000 len: 0008
[00:16:27.469] ssm2_init
[00:16:27.700] ssm2_init
[00:16:27.720] ssm2_init
[00:16:27.730] ssm2_init
[00:16:27.750] ssm2_init
[00:16:27.770] ssm2_init
[00:16:27.790] ssm2_init
[00:16:27.800] ssm2_init
[00:16:27.820] ssm2_init
[00:16:27.840] ssm2_init
[00:16:28.030] kernel get version
[00:16:28.561] validating denso kernel ram area addr: FFFF0000 len: 0008
[00:17:40.845] ssm2_init
[00:17:41.075] ssm2_init
[00:17:41.095] ssm2_init
[00:17:41.125] ssm2_init
[00:17:41.356] ssm2_init
[00:17:41.376] ssm2_init
[00:17:41.406] ssm2_init
[00:17:41.426] ssm2_init
[00:17:41.436] ssm2_init
[00:17:41.626] kernel get version
[00:17:41.946] validating denso kernel ram area addr: FFFF0000 len: 0008
[00:20:00.576] ssm2_init
[00:20:00.806] ssm2_init
[00:20:00.826] ssm2_init
[00:20:00.836] ssm2_init
[00:20:00.856] ssm2_init
[00:20:00.866] ssm2_init
[00:20:00.886] ssm2_init
[00:20:00.896] ssm2_init
[00:20:00.916] ssm2_init
[00:20:01.097] kernel get version
[00:20:01.647] validating denso kernel ram area addr: FFFF0000 len: 0008
[00:20:34.745] ssm2_init
[00:20:34.975] ssm2_init
[00:20:34.985] ssm2_init
[00:20:35.005] ssm2_init
[00:20:35.015] ssm2_init
[00:20:35.035] ssm2_init
[00:20:35.055] ssm2_init
[00:20:35.075] ssm2_init
[00:20:35.085] ssm2_init
[00:20:35.105] ssm2_init
[00:20:35.296] kernel get version
[00:20:35.817] validating denso kernel ram area addr: FFFF0000 len: 0008
[00:21:06.991] ssm2_init
[00:21:07.212] ssm2_init
[00:21:07.232] ssm2_init
[00:21:07.242] ssm2_init
[00:21:07.262] ssm2_init
[00:21:07.282] ssm2_init
[00:21:07.292] ssm2_init
[00:21:07.312] ssm2_init
[00:21:07.322] ssm2_init
[00:21:07.332] ssm2_init
[00:21:07.522] kernel get version
[00:21:08.043] validating denso kernel ram area addr: FFFF0000 len: 0008
zigzagzok
Postby zigzagzok » Sun Nov 26, 2006 2:22 am
took apart the ecu and snapped some pics ... if it is of interest to anyone...
zigzagzok
Postby west_minist » Sun Nov 26, 2006 6:24 am
Most of all, a clear picture of the procressor would really help. That is the main reason for opening the ECU :)
Postby zigzagzok » Sun Nov 26, 2006 4:31 pm
west_minist wrote:Most of all, a clear picture of the procressor would really help. That is the main reason for opening the ECU :)
that was the best pic i cld take :(
subaru engineers scrapped off the serial nos and apply some reflective paint on it...
zoomed in on the pic and this is the best guess of the longest row of nos on the main chip :(
6AF7058F8U
or
BAF7U5BFBU
zigzagzok
Postby west_minist » Sun Nov 26, 2006 5:27 pm
Yeah. I can understand your pain. A 2005 Forrester owner needs a reflash and we are unable to pull the rom.
Postby Jon [in CT] » Sun Jan 28, 2007 1:40 pm
zigzagzok, can you recall which option you selected when you reached the screen shown below?
