New To Logging, Flashing 06' LGT
Postby jackyyuen » Fri Aug 25, 2006 7:59 am
Hi Everyone,
New Help,
I just order the Tactrix 1.2 Cable and trying to connect. Once I got it connected and trying to use ECUFlash to read the rom. The engine light is up.
Even I try to use ECU Expoler to reset the ECU, the engine light is still on.
Please help, I want to remove the engine light, first. Urgent!!
jackyyuen
Re: New To Logging, Flashing 06' LGT
Postby ev8siv3 » Fri Aug 25, 2006 9:04 am
jackyyuen wrote:Hi Everyone,
New Help,
Did you do the Checksum mod?
ev8siv3
Postby 05GarnetLGT » Fri Aug 25, 2006 9:42 am
he didn't flash it
05GarnetLGT
Postby jackyyuen » Fri Aug 25, 2006 9:57 am
I didnt Flash anything.
Quote form other forum "You can always disconnect the battery and pump the brakes a few times to remove the CEL once you've read the ROM. Try on openecu.org, perhaps another person has run into this."
will that work?
Also, is that means pump the brakes, while my bettery is disconnected?
jackyyuen
Postby ev8siv3 » Fri Aug 25, 2006 10:01 am
Oh, yes that would make sense. Disconnecting the battery would cut ECU power, pumping the brakes further drains any charge in the electrical system to ensure its been reset.
So you can't just plug in the cable and jump into ecuExplorer then press F7 with the key on? Make sure the GREEN connector is NOT connected to do a reset.
ev8siv3
Postby jackyyuen » Fri Aug 25, 2006 10:14 am
Thanks ev8siv3,
Are you talking about the green connector on the passenger side? If yes, I will try that after work.
Also, I have the following question:
What is the green connector use for??
When u said the key is "ON" do u mean turn the key to on while the engine still off?
jackyyuen
Postby 05GarnetLGT » Fri Aug 25, 2006 11:12 am
yes, turn the key to the RUN position.
make sure the green test connectors are UNPLUGGED.
05GarnetLGT
Postby autophysics » Fri Aug 25, 2006 4:05 pm
I just started using ecuflash and ths is the procedure I followed successfully 4 times so far. YMMV.
1. Car off - key out of ignition.
2. If applicable remove UTEC or any other piggyback or device that might interfere with flashing - ensure that ECU connections are back to normal.
3. Connect the two sides of the green connector near ECU - under the passenger carpet on the left side of the ECU where the firewall meets the transmission hump.
4. Attach Tactrix cable USB side to your laptop or whatever. (assuming you have the correct drivers already installed)
5. Attach Tactrix cable to OBD II port near hood release lever (driver's side under dash near door)
6. Start ecuflash on your computer.
7. Look at options/port to ensure that it has found the port for the Tactrix cable. If not, then you need to check your drivers and go back to 4. If you notice a new com port and a Tactrix port on your list of ports then the Tactrix port should be selected by default. This may work for others but I found more success using the newly created com port (highest com port) instead.
8. Select Read from ECU
9. Choose correct vehicle and click READ - if it says unable to connect to interface then check the connection of the USB side of the Tactix cable. Go back to 4.
10. When dialog box opens instructing you to turn the key on and then press OK button, be prepared to click the OK button quickly.
11. Turn key in ignition to the full-on position then immediately press the OK button on the computer's dialog box. If you get an error then turn ignition back off and go back to 8. It may require half a dozen attempts in my experience before it is successful. For some reason I had more success using the new (highest) com port (see step 7) instead of the defined tactrix port. Don't worry if you hear the car's radiator fans cycling on and off. This appears normal for my car and the reading/writing still worked fine. Once a successful connection is established the fans were no longer cycling.
12. After successful reading, if that is all you are going to do, then you can turn off the ignition. If you are going to write to ECU, then this is the ideal time since you've already established a good connection.
13. After you are finished reading/writing then turn the ignition off and remove the key.
14. Disconnect the green connectors from 3.
15. Disconnect Tactrix cable from ODB II port.
16. Start Car. Don't be alarmed if takes quite a few cranks or a couple attempts to get the car started. If after starting you have the cruise light flashing or CEL (check engine light) on, then turn off car and start it again a few times to see if it clears. It cleared for me after 3 starts when it happened the first time I tried using ecuflash. It's not happened again in subsequent uses.
17. Enjoy.
autophysics
Postby jackyyuen » Sat Aug 26, 2006 6:56 pm
Thanks a lot!! autophysics
Very detail instructions,
Just one more question,
9. Choose correct vehicle and click READ <-- What car should i pick for my 2006 Legacy GT Automatic??
Thanks.
:D
jackyyuen
Postby 05GarnetLGT » Sat Aug 26, 2006 8:30 pm
06+ DBW
05GarnetLGT
Users browsing this forum: Bing [Bot] and 0 guests
