can flash an 06 wrx
Postby alwaysinboost » Mon Oct 30, 2006 9:59 am
thats where I looked. On the ROM itself it says its inherited from STI05base, so I tried deleting that but still nothing.
alwaysinboost
Postby merchgod » Mon Oct 30, 2006 10:59 am
Do a search on your hard drive for the A8DH200X.xml and A8DH201X.xml. Delete these files. Put the attached files in your rommetadata/Subaru/wrx directory.
A8DH200X.xml
(9.69 KiB) Downloaded 708 times
A8DH201X.xml
(468 Bytes) Downloaded 663 times
merchgod
Postby alwaysinboost » Mon Oct 30, 2006 7:05 pm
I replaced both of those files with the ones you posted, it didn't change anything. I still can't get the ROM's to re-inherit another deff....
alwaysinboost
Postby merchgod » Mon Oct 30, 2006 8:39 pm
When you replace these files you don't have to inherit anything. If you open up a 201x rom now, it should show the tables. Other than that, I don't know what you're doing unless you are replacing the files in the backup directories (which also have a rommetadata directory). Make sure you are replacing them in the ecuflash/rommetadata/subaru directory, not the ecuflash/backupxx, etc.
merchgod
