stage 2 06 STI
stage 2 06 STI
Postby slo06sti » Mon Jan 14, 2008 10:52 am
Can someone take a look at the logs I pulled last night, And let me know if there is anything I should worry about. I just flashed stage 2 with an xpt base map for now. The iam numbers are wacked because we used the value for an 02 because we weren't sure of which one to use. Also I'm getting a little backfire from full throttle to closed throttle pulls.
Thanks in advance.
Data logging 2 pulls 13-01-2008 12h43m46s.csv
2 pulls 3rd gear from 3k, deleted unnecessary logging.
(2.6 KiB) Downloaded 647 times
slo06sti
Mapping
Postby Bamofo » Thu Jan 17, 2008 8:31 am
For anyone to tell if something is wrong you need to datalog the correct information. You have some useful stuff up there but need more info on the tune... are you looking to run 19PSI when wide open? if so you dont have enough initial Wastegate Duty Cycle Because it curves off at 4100 rpms on the second pull. You need to redo the pulls with more info about your setup and add in Feedback correction as a log, and fuel injector duty cycle. Lastly you need to add in the Total timing your running in your logging so you dont blow it up from too much timing. Change Engine load to G/rev too for easy viewing. Good luck!
Bamofo
Postby slo06sti » Thu Jan 17, 2008 9:19 am
I will add these parameters and redo the logs this weekend. I will post them as soon as I get them. Thanks for the help.
slo06sti
Postby slo06sti » Thu Jan 17, 2008 9:22 am
double post
slo06sti
Postby slo06sti » Thu Jan 17, 2008 9:38 am
So after taking a look at the map it shows target boost at 18 psi at 5200 rpms. on my second run I hit 19.1 psi at 3900. Why would I be over boosting? Thanks
slo06sti
Postby ctoyama » Thu Jan 24, 2008 9:20 am
What's your target at 3900? 18 psi as well? Check your wastegate duty cycle for this operating condition. An over agressive setting here could cause overboost.
ctoyama
