Page 1 of 4
ecuEdit v2.4 (Log & View & LC-1 & LM-1 support)
PostPosted: Mon Jan 16, 2006 11:36 pm
by epifan
Main features
Logger
- Innovate Wideband Lambdas support (Innovate ActiveX component)
- SSM (Subaru Select Monitor) support, DTC reader, Custom Memory Logger
- Mitsubishi MUT support
- Custom graphs quantity (2 parameters on each graph)
- Custom dash item quantity (grid X by Y)
- Scheme saver/reader. Save/restore all selected log parameters
- Warnings (set Max,Min values for each Log parameter)
- All Logger parameter's description in XML
Log Viewer
- Functions
- Calculated Custom Parameters
- Graphs, Custom 2D,3D graphs
- RPM and Speed based road dyno
- Custom log table with graph (surface, bar plot)
- Logs overlay (shifting, hiding)
- Range selector, quickly select log data by range. Example: select full throttle range for custom 2d,3d graph analysis.
ROM Editor
- 1D,2D,3D maps
- graphs in 2D and 3D (surface with 360 degree rotation and irregular feature)
- Data Interpolations
- LogLink (link Log
- ECU compare by map list with Source,Compared,Difference table and graph view ability
- HEX Viewer with compare feature (split screen, color difference visualization, navigation) and custom data-functions
- Single map compare from any ECU
- Map and Log link support. Show cells in map which are used by ECU log.
- Built-in editor for all ECU descriptions
and more
- All ECU descriptions in XML
Supported Hardware Cables
- OpenPort 1.2 (flashing support)
- OBDII cables (only for logging)
Editor desktop screenshot
Logger screenshots
Log Viewer screenshots
PostPosted: Sat Feb 25, 2006 11:45 am
by IndyRacer
Epifan - your stuff just keeps getting better! Thanks for all of the updates.
Now for a request. Is there any way you could facilitate overlaying two data logs? I would like to be able to overlay two logs and use the Start-End function or the Select By Range feature to be able to line up the two runs at a starting RPM value, for example. Then I could see how rpm's climb versus time for two different setups, for instance. Also, it would be nice to be able to plot load versus rpm for two different logs at the same time. Think this would be possible? Thanks.
PostPosted: Mon Mar 06, 2006 10:48 am
by epifan
I'm adding log overlay support in ecuEdit. Download a new version at
http://forums.openecu.org/viewtopic.php?p=2864#2864
2D, 3D log overlay would be in next releases :wink:
PostPosted: Thu Mar 09, 2006 8:21 am
by IndyRacer
thanks Epifan! That rocks! Much easier than having to do a bunch of Excel files. Can't wait for the next revision.
PostPosted: Tue Jul 04, 2006 10:16 am
by epifan
Ok, I'm decide to include ECU connectivity in ecuEdit - and SSM support it's a first step, MUT is next :wink:
So, that's a teaser - release would be on weekend, I'm hope :wink:
PostPosted: Tue Jul 04, 2006 11:04 pm
by xswrex
epifan this looks fantastic!
PostPosted: Wed Jul 05, 2006 8:41 am
by ev8siv3
Great work! If you need a place to store your releases I can host them on my server. http://www.osecuroms.org , can't wait to see these new releases and features!
PostPosted: Wed Jul 05, 2006 9:20 am
by swifty
That looks great. Any thoughts on including wideband integration ?
PostPosted: Wed Jul 05, 2006 9:27 am
by epifan
swifty wrote:That looks great. Any thoughts on including wideband integration ?
This is in "to-do" list, but I need protocols description. LM-1 or LC-1 would be prefer.
PostPosted: Wed Jul 05, 2006 9:53 am
by 05GarnetLGT
YES! you are awesome!
I was SERIOUSLY considering buying deltadash because of the wideband integration and now I don't have to!
PostPosted: Wed Jul 05, 2006 10:32 am
by NeverLies
Enjoy:
http://www.innovatemotorsports.com/support/download.php
and direct link to the SDK:
http://www.innovatemotorsports.com/supp ... KSetup.zip
PostPosted: Wed Jul 05, 2006 10:59 am
by gregsachs
aem uego is 9600/8/n/1, does 2 lines of initialization info and then just spits out ascii text of afr in decimal followed by a cr/lf.
ie
12.1
12.2
12.4
etc
Oh, and the uego is a send-only device, hooked up via serial send line and ground only, so the protocol _must_ be simple.
PostPosted: Sun Jul 09, 2006 9:45 am
by epifan
Ok, new version with SSM support coming very soon :wink:
PostPosted: Sun Jul 09, 2006 11:03 pm
by 00WReX
I cannot find the download for 1.2.0.72
Could you please point me in the right direction.
Cheers,
Shane
PostPosted: Mon Jul 10, 2006 1:41 am
by Nozay33
For Zeitronix Wideband meter: http://project802.net/zt2packet.php
8)
