HELP!! ECU map issues
Postby gedik74 » Thu Sep 01, 2011 7:34 am
Hi...I'm basically new to this ecuflash thing...I have issues when I view all my map and I am not sure what to do next As if ecuflash is reading all the wrong address from the xml file. I'm hoping all the seniors could advice what to do. You can see the sample for the High octane fuel map below which is totally different from stock ecu map.
FYI - I'm using an Evo 9, AUDM ,year 2006
Thank you in ad.vance.
Upper map is the original map from my evo 9 whereas below is the stock evo map i got f internet
Comparison My Map vs Stock Evo 9.jpg (399.15 KiB) Viewed 4454 times
gedik74
Re: HELP!! ECU map issues
Postby todd-w » Thu Sep 01, 2011 10:34 am
wrong xml file , whats the original rom id ??? or attach the rom file on here
todd-w
Postby gedik74 » Thu Sep 01, 2011 7:04 pm
The internal ID is 88570008. But it inherits 88580013. Tried to inherit back to 88570008 but still not possible...What should i do next
gedik74
Postby todd-w » Fri Sep 02, 2011 2:59 am
it should inherit evo9 base try these
evo9base.xml
(18.09 KiB) Downloaded 858 times
88570008.xml
(35.78 KiB) Downloaded 810 times
todd-w
