cboles wrote:Similarly, there is really no harm in leaving the flash jumper connected, unless you think that you will go through all of the steps in EcuFlash to flash your ECU accidentally. I leave those connectors in my car all of the time. It is only the test mode connector you must connect / disconnect.
My personal preference is to leave the flash block off if I don't plan on flashing. That way if I accidentaly push the wrong button (hasn't happened yet) it won't accidentaly flash when I just want to read... that's all. In the end we all do what we want, I just wanted to make it clear above that the white block wasn't nessacery for the reading process... something a lot of newcomers aren't aware of.
