Got error problem, need help! Thanks
Postby wrx-blue-mica » Tue Nov 07, 2006 8:51 am
After following everystep and I got this error occurred message when reading the ECU. Please help what should I do to fix it? Thanks
Print Screen Ecuflash Problem.jpg (106.24 KiB) Viewed 13765 times
wrx-blue-mica
Postby bolster » Thu Nov 09, 2006 5:38 pm
I'm getting the same error with mine.
bolster
Postby wrx-blue-mica » Thu Nov 09, 2006 9:30 pm
OK .. I forgot to connect the jumper flash socket. When I connect that flash jumper + green connector everything works now.
wrx-blue-mica
Postby Freon » Thu Nov 09, 2006 9:37 pm
Year? Model? Market? What cable? Exactly what steps did you take? What is the ECU id number? What powertrain?
Not too many people from Indonesia around here, so you'll need to fill us in.
Postby wrx-blue-mica » Fri Nov 10, 2006 10:29 am
Hi Freon
My car spec:
- GDA WRX is year 2002 Aussie version Right Hand Drive non AVCS
- The flash jumper I can use is the four pin that suppose to be for 2003.
- Stock Engine is 2.0lt but upgraded to 2.35ltr EJ22 close deck block
- Stock gearbox is 5 speed (Old STI Spec) but upgraded to 6 speed JDM STI
The steps I took were exactly like the instruction from OpenECU web but I forgot to plug the flash socket. After I plugged it everything ran smooth.
I use Tactrix Cable and their jumper too.
ECU Revision: A4SE900I
ECU Version: AH570
Anything else you need to know, feel free to ask.
Are you the same Freon from NASIOC?
wrx-blue-mica
Postby wrx-blue-mica » Fri Nov 10, 2006 10:34 am
Freon wrote:Year? Model? Market? What cable? Exactly what steps did you take? What is the ECU id number? What powertrain?
Freon .. how to adjust or calibrate the MAP sensor? I am going to install turboxs MAP sensor. Thanks
wrx-blue-mica
Postby Freon » Sat Nov 11, 2006 2:36 am
Yes, same Freon.
Well that ECU should be supported. Ecuflash has XML for it. Do your fans start to cycle when you try? Did you get the green test connector connected? Sure you are hitting the "OK" button on Ecuflash IMMEDIATELY after you turn the key? Turn the key to run, or just accessory? It is very important to be fast. Since ECUFlash has an "OK/Cancel" box to confirm reading or flashing, you should bring up this screen before you turn the key so all you have to do after you turn the key is click the "OK" button. You could also try clicking OK then turning the key after.
There should be maps controlling the MAP sensor scaling, it is a question of if they are found in your model ROM. I've noticed they are not for many models.
Postby wrx-blue-mica » Sat Nov 11, 2006 7:09 am
Hi Freon
Everything run smooth now ... got the Rom image but when I opened it with Enginuity, I can't find the menu to adjust or calibrate the MAP Sensor.
All I got are:
- Boost control
- Wastegate control
- Fuel map
- Timing map
- Knock control
- MAF control
- Rev Limit
- Speed Limit
- Idle control
- Close loop control
- Cel
Did I miss something? Can you help me how to adjust the MAP sensor to turboxs sensor later?
Thanks Freon
wrx-blue-mica
Postby Assami » Wed Nov 22, 2006 11:32 am
Hi,
I have the same error yet I have connected the white and blue connectors and still it is not working I'm having the following info :
[05:31:29.140] Version 1.29.906
[05:31:29.140] 8 memory models read.
[05:31:30.406] 140 ROM metadata models read.
[05:31:30.406] checksum module "subarudbw" loaded.
[05:31:30.406] flashing tool "wrx02" loaded.
[05:31:30.406] flashing tool "wrx04" loaded.
[05:31:30.406] flashing tool "sti04" loaded.
[05:31:30.406] flashing tool "sti05" loaded.
[05:31:30.406] flashing tool "mitsukernel" loaded.
[05:31:30.406] flashing tool "mitsukernelocp" loaded.
[05:31:30.406] flashing tool "mitsubootloader" loaded.
[05:33:10.546] ssm2_init
[05:33:10.718] ECU ID is 3D 44 59 30 05
[05:33:10.718] ssm2_cmd_0x81
[05:33:45.203] ssm2_init
[05:33:45.359] ECU ID is 3D 44 59 30 05
[05:33:45.359] ssm2_cmd_0x81
- Year? 2005
- Model? STI 2.0L
- Market? JDM ( I think , it is middle east specs so I assume it is JDM)
- What cable? OpenPort Universal for Mitsubishi and Subaru
- Exactly what steps did you take? I have installed software successfully . Have connected OBII connector and the white and blue to the white and green connectors ,open the ignition ,Pressed their read from ECU button yet I'm having the error !!!
- What is the ECU id number? 3D 44 59 30 05
What powertrain? 6SPEED non DSSD
Assami
Postby wrx-blue-mica » Wed Nov 22, 2006 8:58 pm
To make it read the stock ECU:
- Connecting to OBD port using Tactric Cable (have to use this Tactrix Cable)
- Connect the flash jumper block
- Call the ECUFlash program
- Click Read Rom
- Pop up menu asking to click ok right away after switch the starter to turn on the ignition but don't start the engine (last step before crank the engine)
- Reading the Rom
- Save the rom Image
- Finish & Open with Enginuity.
Those were the steps I took. Hopefully this will help .. :)
wrx-blue-mica
Postby Assami » Wed Nov 22, 2006 11:11 pm
i did all that :(
Freon, any help ?
Assami
Postby wrx-blue-mica » Wed Nov 22, 2006 11:30 pm
Assami wrote:i did all that :(
Freon, any help ?
Maybe you need to do XML writing to generate your ECU definition but I don't know how to do that.
wrx-blue-mica
Postby Assami » Thu Nov 23, 2006 12:37 am
Freon, any help ?
" XML writing " can you explain ?
Assami
Postby wrx-blue-mica » Thu Nov 23, 2006 1:05 am
Freon, any help ?
Better to ask Freon or someone here who really knows about it.
If I am not wrong, this XML writing is for generate the definiton of your ECU. If you ECU definiton is not in the ECUFlash table list yet than ECUFlash can't read your stock ECU Rom Image.
With XML Writing done than ECUFLash can read your stoc ECU Rom Image.
Just my 2cnt.
wrx-blue-mica
Postby wmcdonal » Fri Dec 08, 2006 5:22 am
Assami
If I read this correctly you used both the white and blue connectors?
The blue connector is for a different model WRX, I think you should just connect the white connector and join the two existing green plugs.
Can someone tell me what the white connector is jumping, and why it is required to read the ECU on the later models.
I am trying to read the rom from an ECU on the bench and I get the same error Assami gets, I wonder if I need to simulate this reflash connector in my wiring, but I don't know what it is doing.
wmcdonal
