Got error problem, need help! Thanks
Postby Assami » Sat Dec 09, 2006 12:34 am
wmcdonal wrote:Assami
If I read this correctly you used both the white and blue connectors?
The blue connector is for a different model WRX, I think you should just connect the white connector and join the two existing green plugs.
Can someone tell me what the white connector is jumping, and why it is required to read the ECU on the later models.
I am trying to read the rom from an ECU on the bench and I get the same error Assami gets, I wonder if I need to simulate this reflash connector in my wiring, but I don't know what it is doing.
I DID ALL THE CONCTING YOU THINK OF .... BUT NO LUCK :(
Assami
Postby Evo4Mad » Sat Dec 09, 2006 1:51 am
you need to ground the init wire, do you know which wire it is on your ecu? you should have one b+, one ground, one battery backup, one data line, one init wire grounded.
Postby wrx_aruba » Thu Dec 14, 2006 4:44 am
having the same error
WRX from Aruba, 2005
[02:44:54.527] ssm2_init
[02:44:54.687] ECU ID is 3D FFFFFFA4 58 30 05
[02:44:54.697] ssm2_cmd_0x81
wrx_aruba
Postby Twinturbo » Thu Dec 14, 2006 4:56 am
Have you connected to your ecu correctly?
http://www.scoobypedia.co.uk/index.php/ ... urECU#toc4
Twinturbo
Postby tverdek » Mon Dec 18, 2006 10:42 am
check out my response to this post :
http://forums.openecu.org/viewtopic.php?p=11054#11054
tverdek
Postby Assami » Tue Dec 19, 2006 10:02 pm
thanks
Assami
