which cable to get on the limitless site. does it matter which one. specifically which one. i got a mirage w/evo 4 swap planning to go with an evo 8 ecu....? which one is best to suite to reflash evo 7-8 ecu on the evo 4.
EvoScan HighSpeed Mitsubishi/Subaru USB Datalogging Cable
(also known as OpenPort 1.3U Cable)
Datalogging and ECUFlash Reprogramming Cable.
High quality and high performance 12pin + 16pin datalogger/reflash cable, capable of extreme high speeds.
Perfect for EvoScan, StiScan, EcuFlash, OBDII software.
Specifically supports 1994-2005 Mitsubishi vehicles for EFI, AYC and ABS systems. Bonus! allows reprogramming of Subaru WRX/Sti ECUs and Mitsubishi Evo factory ecus via EcuFlash (included reflash connector) Also Supports 1999-2006 Subaru SSM-II vehicles for datalogging.
____________________________________________
EvoScan 2006+ Mitsubishi/Subaru ELM327 CAN Protocol USB Cable
High quality and high performance datalogger cable, capable of extreme high speeds.
Perfect for EvoScan, and supports all U.S. OBDII vehicles since 1996-2007, and all elm327 software. Includes support for CANBUS vehicles
For vehicles such as DSM/Subaru/Mitsubishi/3000GT I would highly recommend using the specialised Datalogger/Reflashing cable below.
