Hi,
I have bought an ECU from a E8 260 to fit in my EDM E6 RS2.
Can i upload a E7 rom to the E8 ECU or not?
Will it be safe to run my E6 with a Ralliart Rom from E7 or E8?
Thanks,
Pedro
Amukinado wrote:But can i read the E6 rom from my OE ECU with ECU Flash?
Amukinado wrote:And can i write my E6 rom to the E8 ECU?
radsdau wrote:FIRST: make sure you read and back up your original ROM file!!
If you're running your car on a ROM not made for it, it's likely to be BAD. You will almost certainly have to make a custom tune.
You can put he E7 into E8 ECU, but it will probably not run. I think the immobilizer works differently. Either way, it's no big deal; you can always put your original ROM back in.
I am also pretty sure that the ECU pin functions are not the same (there will be other people who can confirm this).
