Type UK STI My04 (53 plate)
Postby Ren » Tue Oct 23, 2007 5:00 pm
Hi There!
This is the first ECU I have read with my tactrix cable. I cannot get the ROM readable in any software. (A4RN2000)
I have compared it in hex to the closest rom I have available (A4RN1000) and it seems a little small in file size?
ECU read fine in ecuflash, but said the rom was unreadable afterwards.
Any ideas? - ROM image attached
Cheers!
Ren
My04STIppp.hex
(160 KiB) Downloaded 694 times
Ren
Postby radsdau » Tue Oct 23, 2007 8:10 pm
ROMs from these ECUs occupy only 160k of flash. There is a 32k RAM window in the middle of the file which if not removed, makes the file 192k.
Postby Ren » Wed Oct 24, 2007 1:32 am
Can this be added to make it readable?
Can it be reflashed?
Cheers!
Ren
Ren
Postby radsdau » Wed Oct 24, 2007 4:02 pm
Sounds like there is no definition for this ROM type. Use XMLWrite to generate a 'starting point' definition for your ROM; you should find it somewhere on this forum.
Or you could use this one I just made for you. I have not checked it; it is the raw output from XMLWrite.
A4RN2000.XML
(95.98 KiB) Downloaded 526 times
Postby Jon [in CT] » Wed Oct 24, 2007 4:31 pm
Attach a copy of your ROM to a post at http://www.enginuity.org/viewforum.php?f=8.
