by Freon » Wed Oct 10, 2007 10:08 am
Loose boost control line, bad boost control solenoid, etc.
Do you happen to get about 7-8psi max? That is the default wastegate spring pressure on that turbo.
A log file with manifold pressure, wastegate duty, throttle, and RPM would be helpful.
