CPC Valve Duty Ratio (%)
Postby west_minist » Fri Jan 06, 2006 6:55 pm
Anyone know what this is?
Re: CPC Valve Duty Ratio (%)
Postby crispyduck » Sat Jan 07, 2006 1:01 am
west_minist wrote:Anyone know what this is?
It is the Canister Purge Control (CPC) solenoid valve duty ratio.
The charcoal carbon canister is part of the vehicle's Evaporative Emission Control System and is purged by a vacuum operated purge valve. The ECM controls vacuum to this valve through the Canister Purge Solenoid. This data field displays the percentage of time the canister is being purged over a predetermined time interval. On most vehicles the purge solenoid is energized to inhibit purging and de-energized to permit purging of the charcoal canister. This solenoid is energized during a cold engine condition and is de-energized after warm-up when the engine is above a specified RPM. Canister purge allows collected fuel vapors in the canister to be drawn into the intake manifold for burning. Canister purge on some vehicles is controlled through a combined EFE/EGR/Canister Purge solenoid unit. Information source: Project Transam
In summary, it appears this is part of the emmision control system thus not an interesting parameter to be tuning - no performance gain! :)
Postby west_minist » Sat Jan 07, 2006 7:25 am
All sounds wonderful, but how does nit affect the engine?
Can it be fault?
Postby haha » Sun Jul 15, 2007 5:02 am
My ECU is throwing a code for this
P0485 or P0458 - I forget which one
but my rom doesnt allow me to "disable" it
how do I go about solving this ?
Help !
haha
Postby Freon » Sun Jul 15, 2007 8:44 am
It won't hurt anything if it doesn't work right. It is just evaporative emissions stuff.
west: Not sure how to explain how it does not affect engine operation. I don't think the burden of proof is to explain how something does not affect engine operation.
crispy: why can't you disable it? And you really need to know exactly which code you're getting.
Postby crispyduck » Sun Jul 15, 2007 12:49 pm
I think Freon means 'haha' ;-)
Postby west_minist » Wed Aug 15, 2007 6:38 pm
Freon wrote:It won't hurt anything if it doesn't work right. It is just evaporative emissions stuff.
Thanks Freon and everyone.
Postby thejean » Sun Nov 11, 2007 7:19 am
Is it normal for a cpc valve duty ratio to ossicllate if te AFRs are oscillating?
thejean
Postby Freon » Sun Nov 11, 2007 8:17 am
I don't think the two are necessarily connected.
Postby Dougnutz » Sun Nov 11, 2007 4:01 pm
I'm pretty sure Freon is right about them not being related.
Most cars cycle the cpc during cruise conditions and it normally oscillates when it is on.
Dougnutz
