Can anyone make some icons for me?
Postby cboles » Thu Nov 03, 2005 11:14 am
I'd like to put some nice modern looking icons on the new EcuFlash GUI app I'm almost done writing. Sort of like what these types of companies offer:
http://www.stockicons.com/browse.asp
Does anyone out there have the skills to help with something like this? I would need ~10 icons to start, and then a few more of the same style for the map editing part of the software.
Postby megafrenzy » Thu Nov 03, 2005 3:32 pm
Give me an idea of what you want for one of the 10 and I'll take a stab at it. If you like it, I can do them all.
megafrenzy
Postby cboles » Thu Nov 03, 2005 5:59 pm
Thanks.
Here is what I need for right now - The first 5 actions I could use some fairly stock icons for, but it would be nice if all of the icons have a consistent look. A 48x48x24bit PNG file would be a good starting point for each icon. I can scale those down for different resolutions the app might need. I've attached an icon I though was interesting for "write to flash", but really I would be happy with any set of visually pleasing icons that aren't too "loud".
* EcuFlash application icon
* Icons for the following actions
- Open an existing ROM file
- Save the ROM under a new name
- Save the log file under a new name
- Exit the application
- Show the application's About box
- Read from ECU's flash memory
- Write currently loaded ROM image to ECU's flash memory
- Test write currently loaded ROM image to ECU's flash memory
- Compare currently loaded ROM image to ECU's flash memory
- Simulate ECU using currently loaded ROM image for ECU's flash memory
Postby cboles » Sat Nov 05, 2005 4:22 pm
The software is ready... I need icons bad! :cry:
