Cant read 06 WRX
Cant read 06 WRX
Postby frost_wrx » Thu Nov 16, 2006 1:24 pm
log reads like this every time I try to read my ecu, this is an 06 WRX, green flash cables are connected under steering column:
[00:25:01.656] Version 1.29.906
[00:25:01.656] 8 memory models read.
[00:25:03.000] 141 ROM metadata models read.
[00:25:03.000] checksum module "subarudbw" loaded.
[00:25:03.000] flashing tool "wrx02" loaded.
[00:25:03.000] flashing tool "wrx04" loaded.
[00:25:03.000] flashing tool "sti04" loaded.
[00:25:03.000] flashing tool "sti05" loaded.
[00:25:03.000] flashing tool "mitsukernel" loaded.
[00:25:03.000] flashing tool "mitsukernelocp" loaded.
[00:25:03.000] flashing tool "mitsubootloader" loaded.
[00:28:02.046] ssm2_init
[00:28:02.203] ECU ID is 43 12 58 41 06
[00:28:02.203] ssm2_cmd_0x81
[00:28:02.250] ssm2_cmd_0x83
[00:28:02.296] denso challenge-response
[00:28:02.343] challenge is 54 AE 8C 21
[00:28:02.343] response is 00 42 B3 32
[00:28:02.390] ssm2_cmd_0x10
[00:28:02.750] validating denso kernel ram area addr: FFFF3000 len: 0C28
Tried reinstalling about 5 times now, any help would be much appreciated.
frost_wrx
Postby merchgod » Thu Nov 16, 2006 1:26 pm
What cable are you using? When you unistalled Ecuflash did you also uninstall all the drivers (FTDI/Openport) that were in add/remove programs?
merchgod
Postby frost_wrx » Thu Nov 16, 2006 1:29 pm
Yah uninstalled the 2 openport programs in add/remove, and fidi wont remove no matter how many times I try to uninstall it, and the cable is Tactrix OpenPort logging & reflash cable for Subaru Drive-by-wire vehicles, says openport 1.2 on the ebay auction I bought it off of, but the drivers installed with ecuflash were version 1.3
frost_wrx
Postby frost_wrx » Thu Nov 16, 2006 1:58 pm
are the green connectors that need to be connected together under the steering column or by the ecu itself(passenger side)?
frost_wrx
Postby frost_wrx » Thu Nov 16, 2006 4:28 pm
nm got it
frost_wrx
Postby wrx_aruba » Thu Dec 14, 2006 4:27 am
-pls say how you fix?
wrx_aruba
