Subaru STI UK02-03-pr
Postby batman » Sat Nov 04, 2006 4:14 pm
Just thought you may like this genuine verified p..dri upgrade! Please let me know if its ok on US fuel etc. Thanks, Mark
MY02-STI-UK-PD.hex
(160 KiB) Downloaded 885 times
batman
Postby Nemis » Tue Nov 07, 2006 2:19 am
this file have an "on-off" vtt map (zero ° or 30,23° only ) , why ?
Nemis
Postby swifty » Tue Nov 07, 2006 6:49 am
I would guess it is something to do with emissions, but could be wrong.
swifty
Postby wiklundh » Thu Dec 28, 2006 2:49 am
Looks strange?
Have anybody tested the map?
wiklundh
Postby bendalyn » Thu Apr 19, 2007 2:24 pm
This is a bit off topic but i tried this map in my car (MY02 UK STI) more as a trial than anything - was 1st flash different from the original rom. everything went well (i tried a test flash 1st and a compare). But afterwards the car would crank but not start. i carped myself a bit and then flashed the original back on and everything ok again.
is there something i need to do the initialise the rom or something - i didn't do anything once i'd flashed my orignal back on (short of dis-connecting the flash blocks.
i wonder if it was the immobiliser or something, but i wouldn't expect to be able to crank if it was.
bendalyn
Postby rasheedn » Tue May 01, 2007 2:32 am
tested this on my car eu sti and works fine
1.2 bar
so much smoother than the stock sti crap map!
thanks for sharing:)
rasheedn
Postby planesailing » Tue Oct 23, 2007 5:15 am
It didn't load into my ECU first time either for some reason, I re-loaded my original rom then tried again without turning the ignition off and it loaded fine.
Works well, better accel from low down but seems a bit sluggish up the rev range so I'm going to log it over the weekend and see if it's correcting for knock or if it's just me!! Might just be that the map is much smoother than the standard Type UK map.
I need to do some work on it because I don't have the sports cat or uprated fuel pump that come with the PPP so I was expecting it to have some issues that I could look at by logging it on the car.
vtt map not applicable to my car as its a 2002my and doesn't have the variable inlet cam motor.
planesailing
Postby claudefrog » Wed Mar 05, 2008 4:18 pm
will this map be ok for an STI8?
My car is a UK car
2003 STi UK
I have the decat downpipe, fuel pump and panel filter fitted to my car.. sounds exactly what I need :)
claudefrog
Postby scoobydk » Wed Apr 02, 2008 7:25 am
I guess..
Take a backup of you existing ROM and try it out.. What is the worst thing that could happen ? :-)
scoobydk
