Evo ECU Conversion
Postby Zakie@TIC » Wed Oct 10, 2007 1:09 am
I made an Harness adapter according to these instructions for a IV to use with a USDM VIII ecu part no: MN 132874. No start but get the foll. 3 MIL codes:
1. P0183 Fuel Temperature Sensor A Circuit High Input
2. P0113 Intake Air Temperature Circuit High Input
3. P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
Tried this ecu straight up on a JDM VIII RS still no start but showed a MIL with: P0183 Fuel Temperature Sensor A Circuit High Input
This car runs perfect with its own jdm ecu, wonder what's wrong with my usdm ecu or is there anything to do on a usdm ecu to work on a jdm car.
The EVO IV is also a JDM RS.
Thanks,
Zakie@TIC
Postby Zakie@TIC » Mon Oct 15, 2007 8:11 am
Any help to disable the P0183 code? not too sure how to wire the pin 40 on the patch harness. Should I disconnect it from the car's harness end of the patch harness and join it to pin 92 or pin 26 is a better option. What should I do with pin 91.
Zakie@TIC
Postby wreck'd » Mon Nov 05, 2007 6:44 am
Use a 7 rom instead of an 8.
wreck'd
Postby Zakie@TIC » Mon Nov 05, 2007 6:55 am
All is fine except for code P0135 which I believe is the heater circuit for the front O2 sensor. Is there a way to disable it on the program rather than wiring up a resistor?
Zakie@TIC
Postby wreck'd » Mon Nov 05, 2007 9:45 am
Send me your ROM and I will see if I can disable the heater.
wreck'd
Postby Zakie@TIC » Mon Nov 05, 2007 11:48 am
Rom attached,
01_LANCER_EVO7-RalliArt_EDM_450INJ.hex
(256 KiB) Downloaded 874 times
Zakie@TIC
Postby wreck'd » Sat Nov 17, 2007 9:31 am
Just got it now. I will look at it and send it bac a bit later.
Marcus
wreck'd
Postby Zakie@TIC » Sun Nov 18, 2007 12:19 am
Thanks, that will be great help.
Zakie@TIC
Postby Zakie@TIC » Tue Jan 08, 2008 12:54 pm
Wiring up a resistor didn't help to get rid of the heater code, any luck disabling it
Zakie@TIC
Postby BarryC. » Wed Jan 09, 2008 9:29 am
you need a 15 OHM 30watt resistor
BarryC.
Postby Zakie@TIC » Wed Jan 09, 2008 1:05 pm
I'm sure that I went as low as 10ohms but the resistor was a 5watt, does that matter for a brief moment. I wired the resistor to pin 54 and pin 25 (12ve), is my wiring right? I made sure the fault code was cleared using a scanner but kept recurring.
Zakie@TIC
Postby BarryC. » Wed Jan 09, 2008 1:11 pm
yep pin 54 and use an external 12v source not the ECU supply,
use a 15ohm must be 15ohm, 10ohm is too small,
and as the heater circuit draws 1.5 amps or so you will need a high wattage resistor 30w or it will heat up and burn out,
BarryC.
Postby R. Mutt » Thu Jan 17, 2008 1:50 am
BarryC. I noticed you said the immobilizer code for the evo 8 rom was removed. Inspecting the rom I see the immobilizer code set to BD0D.
Could you explain this setting? Reason I ask is I hear that playing with the immobilizer code can be dangerous and have never altered it before. Most people (on evolutionm.net) say you should save a copy of the original rom because if u lose your immobilizer code you're screwed. I usually see a 4 digit number in most ROMs I pull.
I'm looking to do an Evo 7 ECU conversion on an Evo 6. I'll most likely use a JDM 7 GSR stock rom but I'm asking just in case.
R. Mutt
Postby cossie1 » Thu Jan 17, 2008 4:20 am
R. Mutt wrote:BarryC. I noticed you said the immobilizer code for the evo 8 rom was removed. Inspecting the rom I see the immobilizer code set to BD0D.
Just change the BD0D to FFFF and the immobiliser code is then removed ;)
cossie1
Postby R. Mutt » Thu Jan 17, 2008 4:26 am
sweet. Thanks
R. Mutt
