XML definitions for a EU 2002 STI AG820-2591
Postby scotty » Mon May 08, 2006 7:40 pm
all is in the title, if someone has it, i am very interested in! ;)
scotty
Postby Nemis » Wed May 10, 2006 9:47 am
can you upload an ecu image of an ag820? thank you
Nemis
Postby scotty » Thu May 11, 2006 9:54 pm
i am actually waiting for my Openport 1.2 to come but as soon as i'll have it, i will put all i can here! ;)
maybe i'll try with my SSM cable before... wait and see.
scotty
Postby scotty » Sat May 20, 2006 11:10 pm
i've just tried ti get it with ecuflash but enable to do it... :oops:
for this version do i have to put a jumper on or just the green connectors?
at the beginning ecuflash doesn't purpose me my car version and after here what happens:
[00:28:59.561] error loading FTD2XX.DLL
[00:29:28.763] denso02_bootloader_cmd_start
[00:29:29.995] denso02_bootloader_cmd_start
[00:29:31.226] denso02_bootloader_cmd_start
[00:29:32.458] denso02_bootloader_cmd_start
[00:29:33.690] denso02_bootloader_cmd_start
[00:29:34.101] kernel get version
[00:30:41.217] ssm2_init
[00:30:41.417] ssm2_init
[00:30:41.618] ssm2_init
[00:30:41.818] ssm2_init
[00:30:42.018] ssm2_init
[00:30:42.218] ssm2_init
[00:30:42.419] ssm2_init
[00:30:42.619] ssm2_init
[00:30:42.819] ssm2_init
[00:30:43.020] ssm2_init
[00:30:43.370] kernel get version
[00:30:43.871] validating denso kernel ram area addr: FFFF6000 len: 0008
and the an error message
any idea?
scotty
Postby cboles » Sun May 21, 2006 8:50 am
Do you have the correct COM port selected?
Postby scotty » Sun May 21, 2006 11:35 am
it's the same one that i use for ecuexplorer which is working fine,
could it be a problem of "jumpers" like here?
http://forums.openecu.org/viewtopic.php?p=4714
i wanted to know if there's some risk by putting the jumpers (or one(blue/white) i have ordered the both ) on my car and try to read the ecu..?
Is it a problem if my car isn't in the list at the beggining of the soft (i selected 2004 STI because of it)?
thanks
scotty
Postby FrSTi » Sun May 21, 2006 1:50 pm
dadam wrote:it's the same one that i use for ecuexplorer which is working fine,
thanks
Dadam,
You have to install the jumper to write into you Ecu.
Connect the 2 plugs available inside the 3 plugs white connector under your dash, they're close to the greens.
For your car, you must select the WRX 2002-2003 method.
2004 will not make it ;)
If you're not 100% sure about what you are doing, send me a PM ;)
FrSTi
Postby scotty » Sun May 28, 2006 11:07 pm
so i have it since a fews days now...
i had to put the jumper on to read the ecu...
damien_tpu.hex
(4 KiB) Downloaded 793 times
scotty
Postby Nemis » Mon May 29, 2006 2:54 am
4 kb only ?
Nemis
Postby NeverLies » Mon May 29, 2006 3:10 am
4 kb as this is the TPU and not the CPU dump ;)
Postby scotty » Mon May 29, 2006 7:19 pm
:oops:
i've uploaded the wrong one :lol:
What is that one in fact?
So here is the good one!
A4RG060Q.hex
(192 KiB) Downloaded 2052 times
scotty
Postby Nemis » Tue May 30, 2006 3:06 am
tank's a lot.
from Tari site we have:
Revision: A4RG060Q (STI Type UK 01/02 - ag820 2591)
---- 3D MAPS ----
0x0 (0) : Maximum Wastegate Duty (Auto)
0x0 (0) : Maximum Wastegate Duty (Manual)
0x0 (0) : Target Boost Levels (Auto)
0x0 (0) : Target Boost Levels (Manual)
0x238F1 (145649) : Initial Wastegate Duty (Auto)
0x0 (0) : Initial Wastegate Duty (Manual)
0x237BB (145339) : Maximum Wastegate Duty (Auto)
0x2370D (145165) : Target Boost Levels (Auto)
0x2372E (145198) : Target Boost Levels (Manual)
0x0 (0) : Maximum Wastegate Duty - Secondary
0x0 (0) : Initial Wastegate Duty - Secondary
0x213C9 (136137) : Fuel Map (High Octane)
0x21697 (136855) : Fuel Map (Low Octane)
0x21CCC (138444) : Ignition Base Map
0x2223B (139835) : Ignition Correction Map
0x23231 (143921) : VVT - Intake Cam Advance Angle
---- 2D MAPS ----
0x23841 (145473) : Wastegate Duty Compensation - Primary (Atmospheric Pressure)
0x2384B (145483) : Wastegate Duty Compensation - Primary (Air Intake Temperature)
0x2385F (145503) : Wastegate Duty Compensation - Primary (Coolant Temperature)
0x0 (0) : Wastegate Duty Compensation - Secondary (Atmospheric Pressure)
0x0 (0) : Wastegate Duty Compensation - Secondary (Air Intake Temperature)
0x0 (0) : Turbo Dynamics - Proportional Burst
0x2378A (145290) : Turbo Dynamics - Proportional Continuous
0x238C4 (145604) : Turbo Dynamics - Integral Positive
0x2389E (145566) : Turbo Dynamics - Integral Negative
0x0 (0) : Boost Pressure Compensation (Atmospheric Pressure)
0x23975 (145781) : Boost Pressure Compensation (Coolant Temperature)
0x21A0E (137742) : Boost Limit
0x20089 (131209) : Mass Air Flow Sensor Scaling
0x0 (0) : Mass Air Flow Sensor Scaling
0x23EE4 (147172) : CEL Threshold (Boost Solenoid)
---- DATA MAPS ----
0x20000 (131072) : Rom Revision + Calibration ID
0x219DE (137694) : Rev Limit
0x2208F (139407) : Rev Limit Ignition Retard
0x2121B (135707) : Fuel Map Switch Threshold (Advance Multiplier)
0x223A3 (140195) : Knock Learning Range - Engine Load
0x223B3 (140211) : Knock Learning Range - Engine Speed
0x0 (0) : Turbo Dynamics - Minimum RPM
0x23873 (145523) : Advance Multiplier (Boost Disable)
0x23874 (145524) : Advance Multiplier (Boost Enable)
0x23875 (145525) : Turbo Dynamics - Minimum Boost
0x0 (0) : Turbo Dynamics - Minimum Boost
0x23877 (145527) : Minimum Turbo Dynamics Integral
0x23879 (145529) : Maximum Turbo Dynamics Integral
0x0 (0) : Speed Limiter (Boost)
0x20A0A (133642) : Injector Flow Scaling
0x23D72 (146802) : CEL Threshold - Mass Air Flow Sensor
0x2387F (145535) : Per Gear Compensation - Maximum Speed
0x23881 (145537) : Per Gear Boost Compensation (Manual)
0x23886 (145542) : Per Gear Boost Compensation (Auto)
0x0 (0) : Per Gear Wastegate Compensation
0x0 (0) : Intercooler Autowash Threshold - Coolant Temperature
0x0 (0) : Intercooler Autowash Threshold - Engine Speed
0x0 (0) : Intercooler Autowash Threshold - Boost
0x0 (0) : Intercooler Autowash Threshold - Vehicle Speed
0x0 (0) : Intercooler Autowash Threshold - Intake Air Temperature
0x23B3D (146237) : Select Monitor ID
0x219FF (137727) : Speed Limiter
0x2235C (140124) : Advance Multiplier (Initial)
0x2235D (140125) : Coarse Ignition Learning Range (Engine Speed)
0x22365 (140133) : Coarse Ignition Learning Range (Engine Load)
0x223DE (140254) : Fine Ignition Learning Range (Engine Speed)
0x223E6 (140262) : Fine Ignition Learning Range (Engine Load)
0x22397 (140183) : Knock Detection Range (Engine Speed)
0x2239F (140191) : Knock Detection (Minimum Load)
0x0 (0) : Idle Control Limits (AirCon On/Off)
0x0 (0) : Ignition Control Limits
0x21183 (135555) : Closed Loop Threshold - Minimum Coolant Temperature
0x21185 (135557) : Closed Loop Threshold - Maximum Engine Speed
0x21189 (135561) : Closed Loop Threshold (Auto - High Altitude) - Maximum Throttle %
0x2118B (135563) : Closed Loop Threshold (Auto - Sea Level) - Maximum Throttle %
0x2118D (135565) : Closed Loop Threshold - Maximum Throttle %
0x0 (0) : Closed Loop Threshold - Maximum Throttle %
0x21191 (135569) : Closed Loop Threshold (Maximum Vehicle Speed)
0x21193 (135571) : Closed Loop Threshold (Maximum EGT)
0x227BE (141246) : Idle Speed Minimum (Manual) - Air Con
0x227C0 (141248) : Idle Speed Minimum (Auto) - Air Con
0x22A20 (141856) : Idle Speed Minimum (Manual) - High Amps
0x22A16 (141846) : Idle Speed Minimum (Auto) - High Amps
0x22A22 (141858) : Idle Speed Minimum (Manual) - Startup
0x22A1A (141850) : Idle Speed Minimum (Auto) - Startup
so im looking hot do do xml definition from this table and add missing map
Nemis
Postby scotty » Tue May 30, 2006 3:38 am
the xml definitions i had with xml write v6 is very more complete than that!
I have more than 160 differents maps in 1D, 2D and 3D with ecuflash 1.27 :shock:
have i made something wrong?
I also have a lot of with enginuity or ecuedit...
scotty
Postby FrSTi » Tue May 30, 2006 3:56 am
dadam wrote:the xml definitions i had with xml write v6 is very more complete than that!
Nothing wrong, you're fine with that ;)
FrSTi
Postby Nemis » Tue May 30, 2006 4:55 am
i have ecuflash 1,27 but don't have map of this rom,it ask me what is this rom, maybe i have do some error :-)
Nemis
