08 FXT
08 FXT
Postby 06rexwagon » Tue Jun 05, 2007 6:49 am
My friend just picked up the Forester Sports edition and I tried to read his ecu with 1.30 and 1.27 without any luck. Anyone done it or know when ecuflash will support it?
06rexwagon
Postby illmatic » Wed Aug 08, 2007 8:00 pm
I believe the new 2008 XT use a CANbus interface.
illmatic
Postby 06rexwagon » Wed Aug 08, 2007 8:37 pm
Yes it does, and there's an 07 ECU on its way to Colby for R&D right now.
06rexwagon
Postby 06rexwagon » Mon Sep 10, 2007 9:17 am
Bump... Any progress with that ecu Colby?
06rexwagon
Postby haha » Tue Nov 06, 2007 4:36 am
Hiya
bump for news or does the new 1.34 ? take care of it ?
haha
Postby jwright77 » Tue Apr 22, 2008 4:56 am
Bumping this, any luck with the 07-08's ??? I have searched the sf.org and can't find anything on it.
jwright77
Postby Jon [in CT] » Tue Apr 22, 2008 10:28 am
You'll have to wait at least until new OpenPort 2.0 hardware becomes available:
http://www.tactrix.com/product_info.php?products_id=40
Postby haha » Tue Apr 22, 2008 9:30 pm
I hear you about the CAN bus side of things but before anyone goes mad about this please check that the green connectors actually put the car into diagnostic mode - ie - ign on, green connectors together and the cel flashes and various relays click throughout the car and the fan and fuel pump etc cycles
I have come across a few were the green connectors made no difference as the circuit wasnt being completed by the greeen connectors under the dash ! - if you trace your wiring diagram you will find a second set of green connectors on the same circuit - both need to be "connected"
the other green connectors are either above the ecu or under the passenger side door kick panel on the side - sort of under the edge of the dash close to the door hinges area if you follow - subaru's default was for these to be connected but now for some reason they ship disconnected from the factory - hook them up and you good to go !
try this first - its a layer 1 problem
haha
Postby jwright77 » Fri May 30, 2008 6:20 pm
Jon [in CT] wrote:You'll have to wait at least until new OpenPort 2.0 hardware becomes available:
So the 2.0 will support the can bus ecu, I wonder if the 2.0 will be expensive... Looks like it will be out June 15th. I'd be willing to pick one up if someone can help me tune my fxt.
jwright77
Postby radsdau » Sun Jun 01, 2008 3:15 pm
murmurings on other forums suggest the price will be around US$200 or just under. This is not the official word from Tactrix however. Still, great value for what it is.
Openport
Postby wrxxy » Thu Jul 03, 2008 7:56 pm
Whats happen to the Openport 2 ? Tactrix has'nt got it listed anymore! :cry: :cry: :cry: :cry:
wrxxy
