Is it OK to leave the Jumper plug in on a 2002 wrx?
Postby WerdJack » Fri May 25, 2007 7:07 pm
would someone like to describe the sequence of booting up.....and can we leave the jumper plug in after we are done.....
WerdJack
Postby crispyduck » Sat May 26, 2007 11:53 am
'Boot-up process'? Assume you want to reflash. Take a look at:
http://www.scoobypedia.co.uk/index.php/ ... ashingECUs
and the ECU Flash User's Guide:
http://www.scoobypedia.co.uk/index.php/ ... hUserGuide
And yes, leaving the flash block jumper in is fine - I do. You have to disconnect the test mode (green) connector though!
Postby WerdJack » Sat May 26, 2007 6:13 pm
thanks I was wanting to blame my fuel trims on the jumper flash.....the green connectors connected would play havic....heheehe
WerdJack
Postby nperkins » Wed May 30, 2007 4:57 am
What about on a MY04? Can I leave the jumper in while I am on the dyno reflashing? Or do I have to unplug after every flash before doing another dyno run?
nperkins
Postby haha » Sat Jun 23, 2007 11:55 am
all the jumpers on the white flash block do is complete the circuit for a few of the pins of the obd connector - leave em in - if you want confirmation of this yourself - download a copy of your models wiring diagram and trace the wires out - the 2.5 does away with this flash block
haha
