MY03 EDM WRX Offsets
Postby qoncept » Sun Nov 20, 2005 5:44 pm
These are imcomplete.
BOOST_RPM_START = 0x22523;
BOOST_RPM_STOP = 0x22534;
BOOST_THROTTLE_START = 0x22536;
BOOST_THROTTLE_STOP = 0x2253D;
BOOST_START = 0x22540;
BOOST_STOP = 0x22587;
TIMING_RPM_START = 0x21260;
TIMING_RPM_STOP = 0x2127F;
TIMING_LOAD_START = 0x21281;
TIMING_LOAD_STOP = 0x212A0;
TIMING_START = 0x212A3;
TIMING_STOP = 0x213A2;
TIMING_CORR_RPM_START = 0x217AD;
TIMING_CORR_RPM_STOP = 0x217CC;
TIMING_CORR_LOAD_START = 0x217CE;
TIMING_CORR_LOAD_STOP = 0x217E8;
TIMING_CORR_START = 0x217EA;
TIMING_CORR_STOP = 0x218B9;
FUEL_RPM_START = 0x20C74;
FUEL_RPM_STOP = 0x20C93;
FUEL_LOAD_START = 0x20C95;
FUEL_LOAD_STOP = 0x20CB4;
FUEL_START = 0x20CB7;
FUEL_STOP = 0x20DB6;
Worth note is that the boost throttle values (horizontal) are 1 byte instead of 2 as in USDM images.
Postby crispyduck » Fri Dec 02, 2005 12:20 pm
IAM address for a MY03 Euro WRX is 0x020120. This value is useful to 'activate' when using ecuExplorer.
Postby crispyduck » Fri Dec 02, 2005 12:34 pm
qoncept, all,
Has anyone had any luck identfying the other tables for MY03 Impreza 2.0 WRX (EURO) [AH750-5141] above? Only asking as I've just confirmed, via ecuExplorer, that my car seems to be running fine (IAM, AFR, and knock, etc.). I'm now keen to start playing with Enginuity to alter the Wastegate Duty table - replacing my Dawes MBC.
Users browsing this forum: No registered users and 52 guests
