Anyone Got a ROM for an MY99/00
Postby Scott.T » Sat Sep 16, 2006 7:02 am
I have a copy of the performance maps from an Ae801, Ae802 and a Prodrive ECU. It's just the maps & axis for the usual performance parameter, not the entire image.
If anyone has a BIN or HEX file out there I could start having a search for address locations, as I know how to reverse engineer the 'real' values back to 'hex'.
If you have got a ROM, how did you upload it ??
Scott.T
Postby evoman » Mon Sep 18, 2006 7:30 am
evoman
Postby Scott.T » Thu Sep 21, 2006 12:34 am
Cheers,
Did you download this using OpenECU tools, if so which.
Not sure if this has been done already but have found the following maps in the Ae802
Main Fuel Map & Load/RPM Scales
Ignition Map & Load/RPM Scales
Low Octane Ignition Compensation & Load/RPM Scales
High Octane Ignition Compensation & Load/RPM Scales
Boost Target & Throttle %/RPM Scales
Boost Duty & Throttle %/RPM Scales
Boost Limit
And a couple of others that I can't remember at the moment
Will post more info when I'm on my other PC which had the Address locations recorded.
Scott.T
