So what is that we need to do to modify the code (xml table?) and/or hardware to make this work?
Cboles posted the 1.3m schematics (as requested) a while ago and we havent seen anything more from YP.
Is this just a case of a change in jumper wire to initiate the boot strap load?
Or do we/me need to run IDA to figure out where to go?
EvoScan works fine on my 98 Talon TSi AWD and the 98 has both ports,
the OBDII and the flash initiator port (both plugs connect on the OpenPort 1.3m cable).
The EVO 5/6 and 2g dsm's are currently not supported by the EcuFlash software,
but are listed as under development. Tho I think that as far as the 2g dsm's go, only the 98 & 99 will work.
Red
98 Talon TSi AWD
91 Talon TSi AWD
90 Galant GSX
