Fact is ...
Cobb worked the LC-1 into StreetTUNER
The MPS_UTECLogger uses the LC-1
The LC-1 is the standard for stand alone Wideband.
The LC-1 needs to be worked into ECUExplorer. This is a necessity. Unfortunately, I don't think this will happen since Calvin isn't working on ECUExplorer anymore (due to working on RealTime tuning). I really wish Calvin would release one more version of ECUExplorer with LC-1 support. This is unbelievably necessary since you NEED to correlate AFR with the rest of the data in the logs. RealTime tuning is needed ... but what good is realtime tuning when you don't even know the AFR at a particular data point so that you change the Fueling/Timing.
What WILL happen is that epifan will work the LC-1 into his software (EcuEdit). I think that sucks because his program is no longer free.
