Postby 05GarnetLGT » Fri Jul 21, 2006 7:29 am
I dunno if this was there before, but now there is an option to register under help...
I think you can figure out what the future holds for ecuedit.
05GarnetLGT
Postby JRSCCivic98 » Sun Jul 23, 2006 6:35 pm
I know I posted this problem before and apperently you haven't fix it yet epifan. If you open up 2 maps and do a copy and paste from one to the other by the time you get to the bottom 1 d maps (almost done) and open another value the damn program closes out. You cannot imagine how anoying this is!!!!! All that time spent now has to be done again. Add to this the anoying 60 second pause on saves (yeah, I know you're selling a version without pauses) and you can see how much of a problem this is. I suggest you fix this... especially if you're going to sell the program now.
BTW, sorry if this post seems angry, but at the moment I'm PISSED!!! cuz I just wasted all that time.
Fix it!!!
Postby epifan » Sun Jul 23, 2006 10:34 pm
JRSCCivic98 wrote:I know I posted this problem before and apperently you haven't fix it yet epifan. If you open up 2 maps and do a copy and paste from one to the other by the time you get to the bottom 1 d maps (almost done) and open another value the damn program closes out.
This is first time that I'm hear about this problem. Can you describe to me, step by step what are you doing and what's going on with programm.
epifan
Postby JRSCCivic98 » Mon Jul 24, 2006 3:31 am
It's not the first time I've mentioned this.... see page 15 in this thread and read my posts...
http://forums.openecu.org/viewtopic.php ... &start=210
Postby epifan » Mon Jul 24, 2006 6:01 am
JRSCCivic98 wrote:It's not the first time I've mentioned this.... see page 15 in this thread and read my posts...
I fix it about 2 month ago. It's not programm bug - it's windows limitation of opened handles. I put in programm limitation for 300 opened windows. For Win95/98/Me this quantity much more less and this problem must be happened. So, I would fix it again for Win95 users...
epifan
Postby JRSCCivic98 » Mon Jul 24, 2006 6:42 am
Not using 95. I have XP Pro. The closeout of the program now doesn't happen at the same place where it did before, but it still happens. Before it would be about halfway through the 2d maps, now it's 3/4 of the way through the 1d maps.
Postby Spec C Wannabe » Tue Jul 25, 2006 6:13 am
JRSCCivic98 wrote:Not using 95. I have XP Pro. The closeout of the program now doesn't happen at the same place where it did before, but it still happens. Before it would be about halfway through the 2d maps, now it's 3/4 of the way through the 1d maps.
JRS, I would suggest you close the current map that you have just finished copying before openning another one. Doing so will not take up much resource of your computer's memory. Also try to save it often.
I have done the same copy and paste whole map thing as you describe. And to save myself from being mad, I saved my work every 10 to 15maps or so.
Spec C Wannabe
Postby JRSCCivic98 » Tue Jul 25, 2006 11:05 am
I only work with 2 maps at a time. So obviously I cannot close one since I'm working back and fourth on comparisons or copies of the various tables. I've made it a habit to save after each of the 3 table sections, however this is just a workarround and not a fix. I don't do this a lot so it's not a daily thing, but when I do it can be a pain.
Postby epifan » Thu Jul 27, 2006 9:22 am
ecuEdit v2.1.0.77
- SSM Logger: Diagnostic Trouble Codes reader
- SSM Logger: Reset ECU
- SSM Logger: Custom Memory Logger (this version include only one preset for Logging Active Ignition Correction (table 8x8 offset=IAM offset+2)
- Logger scheme saver/reader. Save/restore all selected log parameters, graphs and dash setups and etc.
- bug fixes: (many opened windows bug, etc)
Download ecuEdit v2.1 trial version
epifan
Postby west_minist » Thu Jul 27, 2006 3:32 pm
The Dyno stuff works out to be DD @ medium settings.
The graphs are still very wavy but the results between the 2 programs are very closed.
What you need to add is a second function that would take the regressive line through the data. Can you do this? that would a better look graph for those of us that may want to see it. :)
Postby epifan » Thu Aug 03, 2006 4:49 am
ecuEdit v2.2.0.79
- Innovate Wideband Lambdas support (Innovate ActiveX component). In demo-version Labmda is not writed to Log-file - display only
- Log Viewer : RPM based road dyno
Download ecuEdit v2.2 trial version
epifan
Postby west_minist » Thu Aug 03, 2006 5:54 am
For LC1 support?
Postby epifan » Thu Aug 03, 2006 6:06 am
west_minist wrote:For LC1 support?
LC-1,LM-1,ST-12 supported
epifan
Postby west_minist » Thu Aug 03, 2006 6:14 am
Nice. I will test tonight
Postby Freon » Thu Aug 03, 2006 2:12 pm
Awesome!
