Postby DaBIGOne » Fri Jul 14, 2006 6:37 am
west_minist wrote:You are correct. Its very wavy and the results do not add up. All files produce this.
I use EcuEdit in all tuning, as you can see from my post. The Dyno will complete the usage, making me dump DD.
This would be oe software I would pay for, if I still continue to tune with my new hectic job.
First of all, i would like to apologize for my English, as it is not my native language.
Yes, i saw it too, very wavy, even after smoothing it.
I've been examining my data, and I found out that the speed-sensor is not accurate enough, sometimes it goes up 4 km/h in 250 miliseconds, and then it stays for 750 miliseconds the same.
And the measuring is not accurate enough, let's say 85 km/h could be 84,5 to 85,5 wich makes a lot of difference for the calculation.
In sample 1 jou have a value of 84,6 wich is 85 in the log, then at sample 2 you have a speed of 85,4 in 250 miliseconds time, and the log still shows 85.
So according to the log, in 250 miliseconds there has been een accelecation of 85-85=0, but in reality it was 85,4-84,6 = 0,8 that's a lot of accelecation in 250 miliseconds.
Then you get inaccurate readings.
Maybe it's an option to change your input value to RPM in stead of km/h as the RPM is just a factor of the speed.
So, you take a sample of data at some time, (speed/RPM = factor).
And then you can calculate the speed from the RPM (RPM*Factor = speed).
At least you have a speed-reading at every datasample, and would make the waving a lot less...
Regards, Da BIG One
DaBIGOne
Postby mayday72 » Fri Jul 14, 2006 7:06 am
I have unpacked all files
mayday72
Postby mayday72 » Fri Jul 14, 2006 7:08 am
JRSCCivic98 wrote:Extract everything (not just one file) out of the zip and put it in a directory. That will fix all of everyone's problems. How hard is it to do this people?
I extract all files in one directory
mayday72
Postby wetwilly » Fri Jul 14, 2006 8:46 am
Well, no it won't fix everyone's problems, because this release's zip was missing the ecuedit.INI file, which is necessary to get this program to work. So even if he had extracted the zip correctly (which he did), it still won't work until he manually creates and adds the INI file.
What is hard for newcomers is trying to extract knowledge out of a thread that is cluttered up with posts such as yours.
wetwilly
Postby ev8siv3 » Fri Jul 14, 2006 9:00 am
IAM on 2005 USDM WRX = 52??
ev8siv3
Postby JRSCCivic98 » Fri Jul 14, 2006 12:59 pm
wetwilly wrote:What is hard for newcomers is trying to extract knowledge out of a thread that is cluttered up with posts such as yours.
OK, first of all, STFU. Secondly, you're right the INI file is not in the ZIP, sorry if it wasn't so apperent to me. For those of us that are not "Newcomers" as you put it and have used ecuEdit in the past this does not pose a problem.
Now that we know that just make a ecuEdit.ini file that contains the following and your problems will be fixed.
[Main]
XMLDir=XMLDefs\
XMLWriteParam=1
Postby wetwilly » Fri Jul 14, 2006 1:11 pm
[Main]
XMLDir=XMLDefs\
XMLWriteParam=1
Yes, fixing the INI problem has already been explained by someone else more helpful than you. Maybe you oldtimers should actually read the posts here before making smartass remarks.
wetwilly
Postby JRSCCivic98 » Fri Jul 14, 2006 8:11 pm
wetwilly wrote:Yes, fixing the INI problem has already been explained by someone else more helpful than you. Maybe you oldtimers should actually read the posts here before making smartass remarks.
One more time... STFU. :P So far you're 2 for 2 on useless posts as well.
Postby epifan » Fri Jul 14, 2006 10:01 pm
ev8siv3 wrote:IAM on 2005 USDM WRX = 52??
ecuEdit don't automaticly find IAM or Engine Load. You must select your own correct address in parameter alternative dropdown menu.
epifan
Postby mayday72 » Sat Jul 15, 2006 1:09 am
Thanks large for your advice, I shall search and to make modifications in
.ini a file
mayday72
Postby ev8siv3 » Sat Jul 15, 2006 8:23 am
I realized that and selected mine of 20168 and it still comes up with 52.
ev8siv3
Postby xswrex » Mon Jul 17, 2006 9:33 pm
epifan-> 1 small fix in the CSV file logging.
Force the decimal separator to "." , it will cause problems for users like me who have in their regional settings "," as the decimal separator.
thx
xswrex
Postby impreza666 » Tue Jul 18, 2006 10:23 am
I it possible to have some wornings during the logging?
impreza666
Postby epifan » Thu Jul 20, 2006 11:41 am
So, I'm rebuild ecuEdit as shareware product.
Check new releases on my own forum http://www.epifansoft.com
Download ecuEdit v2.0.0.73
epifan
Postby JRSCCivic98 » Thu Jul 20, 2006 1:43 pm
I'll ask again since you like to cross post in multiple threads. What's up with the "Trial Version/Shareware" thing?
