JECS ROM Download
Postby richh » Sun Apr 09, 2006 5:39 am
west_minist wrote: Ok, I tried the address and only 2 showed some data w/ one moving. Not sure what is it. You can tell me. Advance Multipier is 80224E
The engine load parameter on at least some of the 99/00 ECU's is one byte at 801308, so try that and see what you come up with. The one thing I'm unsure of is what, if any, conversion formula is done to the raw byte returns in order to produce the load value.
x99percent wrote: E**Tek shows load as g/sec of air. This value can be close to (but isn't the same as) the MAF voltage.
The MAF voltage and actual airflow value would never be "close" to each other, as MAF sensor voltage range is between around 1.0 and 5.0 volts, while airflow ranges are anything from a handful of grams per second to over 300, and the relationship between them is non-linear. However, if, as mentioned above, the ECU uses MAF sensor voltage as its primary load value, the scaling is less of an issue.
The ECU either appears to hold a scaling table, or a formula which converts vMAF into g/s. The scaling is distinctly non-linear - the difference in airflow between 1.1 and 1.2 volts vMAF is a fraction of that seen between, for example, 4.1 and 4.2 volts.
The SSM protocol apparently outputs the mass airflow in g/s as a 16 bit value at 0x013 and 0x014. I tried once to read this and cross-reference the MAF voltage value reported at 0x0H1D to deduce the lookup table, but can't get sensible numbers from the 16 bit reading. May be that I got the LS and MS bytes the wrong way round, or may also be that this function only works on the newer ECU's. I'll have another go with the byte order reversed and see what happens.
richh
Postby west_minist » Sun Apr 09, 2006 6:36 am
west_minist wrote:My logging do not show load. I will have to try the addressed. But in dd, no
load.
Ok, I cross reference it and it seems to be a the Idle Control valve.
Just to let you know, I have a non turbo model.
It would be interesting to know if non turbo models in DD have load.
My friend own is MAP (non turbo) and no load is seen, except MAP psi variable
The Ecutek tool for 99+ until some date most probably change the maf to g/sec, maybe from variable from rom. But from that pic (http://195.112.37.59/products/deltaecu/), that is MAF voltage.
Postby x99percent » Sun Apr 09, 2006 8:30 am
west_minist wrote:The Ecutek tool for 99+ until some date most probably change the maf to g/sec, maybe from variable from rom. But from that pic (http://195.112.37.59/products/deltaecu/), that is MAF voltage.
So the MAF voltage only goes up to 2.75V ??
x99percent
Postby x99percent » Sun Apr 09, 2006 8:32 am
Here is a screen capture from the E**Tek software...
I could be 100% wrong... but with as anal as they are, I don't think they would mislabel an axis.
x99percent
Postby west_minist » Sun Apr 09, 2006 8:57 am
That's true.
I believe I need to understand how the load(grams) are calculated.
So we are looking @ mass air flow - g/s
Maf voltage - v
Load - g
Postby Freon » Sun Apr 09, 2006 9:49 am
Guys, that is correct. MAF voltage is converted to load, which might as well be unitless as far as the ECU is concerned. It just takes that load and looks it up whereever load is used as an axis on a map (mainly timing and fueling). It seems to be approximately exponential. There is a 2D Map that is 87x1 (or whatever, it is long!) with an 87x1 column header on the last WRX ROM I looked at.
FWIW, I think a lot can be done to tune intakes by adjusting that table. Once I get into it, I will be using the MAF to load table to flatten out fuel trims to adjust for my intake.
Postby x99percent » Sun Apr 09, 2006 11:36 am
Freon wrote:FWIW, I think a lot can be done to tune intakes by adjusting that table. Once I get into it, I will be using the MAF to load table to flatten out fuel trims to adjust for my intake.
http://195.112.37.59/tuning/induction/ ;)
x99percent
Postby STi6 » Tue Apr 11, 2006 12:47 pm
Here is another ROM to hack away at.
ag340.bin
(128 KiB) Downloaded 938 times
STi6
Postby richh » Tue Apr 11, 2006 2:10 pm
x99percent wrote: I could be 100% wrong... but with as anal as they are, I don't think they would mislabel an axis.
Ah, no, you're correct, the axis isn't mislabeled, but we are talking about different units.
The MAF sensor, located where it is, and being the design it is, by definition measures the total amount of air being pulled into the engine. Hence grams per second being the quantity used by the SSM stream, MAF scaling table and so-forth.
The ECU map you quoted uses grams of air per cylinder per charge, so they're dividing the total g/s figure by engine speed and so-forth.
richh
Postby west_minist » Tue Apr 11, 2006 2:58 pm
STi6 wrote:Here is another ROM to hack away at.
Where you getting these roms from?
Help me get mine :( :( :(
Postby Hitokiri » Tue Apr 11, 2006 2:58 pm
what I really want to see is a ae800 or ae802 - the standard WRX flash for europe
or a ae490 or ae491 which is the standard japan wrx
Postby Hitokiri » Tue Apr 11, 2006 7:55 pm
that second dump seems to be the same as the first???
Postby STi6 » Wed Apr 12, 2006 1:38 pm
Hitokiri wrote:that second dump seems to be the same as the first???
Do you mean mine? First one was encrypted, this one isnt.
STi6
Postby STi6 » Wed Apr 12, 2006 1:40 pm
I've got an AE802 ecu for sale if anyone is interested. It got the stock map on it. Want $200 for it excl postage.
STi6
Postby west_minist » Wed Apr 12, 2006 1:49 pm
Does this model have avcs?
