JECS ROM Download
Postby NoCtrl » Thu Mar 23, 2006 2:10 pm
xswrex wrote:you can try this, who knows it might not be encrypted
This one my be interesting.
32bit instructions will always start at adresses ending with xxx0,xxx4,xxx8,xxxc and they have msb=1
16bit instr can start at xxx0,xxx2,xxx4,xxx6,xxx8,xxxa,xxxc,xxxe.
Because of this theres a special NOP to fill inn holes before a 32bit. This NOP is F000
So, a search for F000 gives plenty matches with the next 32 bit word have msb set.
Now, theres a need for a disassembler...
Anyone else looking at this?
NoCtrl
Postby west_minist » Thu Mar 23, 2006 2:43 pm
How did you get this? Is it an ECUTek flash for a 99/00?
Postby xswrex » Thu Mar 23, 2006 10:59 pm
i took the rom posted above and "processed" it a bit, how this is done i cannot say.....
the ecu id is 0x16 0x04 0x69 0x06 0x05, that makes it a JDM P1 ag340.
I dont know if it is modified or not
xswrex
Postby STi6 » Fri Mar 24, 2006 4:43 pm
I compared the file to a Denso ecu file in a disassembler. I see what you mean by the F000, but surely the values that we want to view/edit will only be 8 or 16 bit?
STi6
Postby NoCtrl » Fri Mar 24, 2006 5:33 pm
STi6 wrote:I compared the file to a Denso ecu file in a disassembler. I see what you mean by the F000, but surely the values that we want to view/edit will only be 8 or 16 bit?
heh, I want to see the code :D
I have not looked at the Denso dumps/ECUs at all,.. ..yet...,
so I dont know how similar processors used in later Denso ECUs are..
I commented on the F000 NOP instruction because:
- mybe confirm m32 processors in JECS ECUs
- mybe confirm a valid uncoded dump
..and after looking at the file, there must be a processor that are close to the m32, but I dont know how close yet..
Do you have/know of a disassembler that can disassemble this file?
NoCtrl
Postby cboles » Fri Mar 24, 2006 5:57 pm
IDA Pro Advanced works fine with M32R. I've used it on Mitsubishis.
Postby NoCtrl » Sat Mar 25, 2006 1:46 am
[quote="cboles"]IDA Pro Advanced works fine with M32R. I've used it on Mitsubishis.
/quote]
Advanced is priced to 639EUR/875USD..
So, there are no alternatives..??
NoCtrl
Postby cboles » Sat Mar 25, 2006 1:57 am
not really that i've seen. i broke down and spent the $875. :?
Postby NoCtrl » Sat Mar 25, 2006 4:44 am
I have started on a python script, with a optimistic goal of disassemble the m32 processor instructions.
I have some spare time now, and doing this mostly as a learning experience.
I havent done any programming in 10 years, and never anything in python, so things move slowly forwards.
If I can get it usable/working I will publish it..
NoCtrl
Postby STi6 » Sat Mar 25, 2006 5:24 am
The software dissasemler I use is W32Dasm. It's not hard to get a hold of.
*edit*
I've realised that disassembling these roms with a normal Win32 80x86 dissasemler is pretty much useless, since they are made to run on a MR32 processor :?
STi6
Postby Hitokiri » Sat Mar 25, 2006 4:39 pm
There are obvious maps in this file, but nothing that screams ignition and fuel maps like I have seen in denso ecus
there seems to be some 8x8 and some 16x16 maps int ehre for sure.
Postby west_minist » Sat Mar 25, 2006 5:21 pm
Hitokiri wrote:There are obvious maps in this file, but nothing that screams ignition and fuel maps like I have seen in denso ecus
Hey Hitokiri, what are you using to view the file?
Postby xswrex » Mon Mar 27, 2006 4:08 am
this looks like a main fuel map
LOAD @ 0x136f
RPM @ 0x137f
AFR @ 0x138f
xswrex
Postby Hitokiri » Mon Mar 27, 2006 5:46 am
xswrex I agree
I am not sure of the conversions I used. RPM seems to be right in the normal *50 conversion. Load is unsure at this point as we cannot be sure what these ecus use for load. I know I have a engine load parameter that shows up in my ecuexplorer that is 0-100% so I simply did [value]*2 to get data that looked good for that scaling.
The data conversion was a guess too keeping the convention of the ecuedit tools with: 14.7*(128/[value]) seemed to be simple enough and give good results.
Here is the map in question:
Fuel Map from UK P1? Tuned?
Postby STi6 » Tue Mar 28, 2006 12:40 am
These ECU's use a combination of factors for load according to my tuner. Some of these factors are, MAF sensor g/s. Throttle position and maybe some others.
I was in my car yesterday when it got tuned and the Load Values are all numbers with decimals, not real numbers like 50,60,70 etc.
STi6
