by cboles » Fri Mar 24, 2006 10:18 am
The 1.0G can technically work, because the DBW ECUs I have seen generate theire own reflash voltage. Some may still look for 12V on this line though, even though the don't use it. One issue is operational speed. The DBW reflash software I am running right now operates at too high of a baudrate for the OpenPort 1.0. I will eventually change the software to operate at a slower baudrate for the 1.0, but probably not in the first release. I will try to support all of the existing versions out there.
