2006 JDM Mitsubishi Outlander
Postby scientist » Sun Sep 20, 2009 6:06 pm
I tried reading the rom from the Ecu, and ECU flash gave me a failure, I tried starting the vehicle afterwards and was a no go. The check engine light and a bunch of other lights started lighting up on the dash and MMCS. I tried using the Exit programing state but still got an error. Anyone has any suggestions?
Here is a log
[13:03:29.031] EcuFlash Version 1.42.2595
[13:03:29.031] OS Version Windows XP
[13:03:29.031] Qt Version 4.5.0
[13:03:29.031] 56 memory models read.
[13:03:29.031] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[13:03:33.296] 344 ROM metadata models scanned.
[13:03:33.296] checksum module "subarudbw" loaded.
[13:03:33.296] checksum module "mitsucan" loaded.
[13:03:33.296] flashing tool "wrx02" loaded.
[13:03:33.296] flashing tool "wrx04" loaded.
[13:03:33.296] flashing tool "sti04" loaded.
[13:03:33.296] flashing tool "sti05" loaded.
[13:03:33.296] flashing tool "mitsukernel" loaded.
[13:03:33.296] flashing tool "mitsukernelocp" loaded.
[13:03:33.296] flashing tool "mitsubootloader" loaded.
[13:03:33.296] flashing tool "shbootmode" loaded.
[13:03:33.500] flashing tool "shaudmode" loaded.
[13:03:33.500] flashing tool "subarucan" loaded.
[13:03:33.500] flashing tool "mitsucan" loaded.
[13:03:37.625] 52360016 (78 tables) inheriting evo10base (101 tables)
[13:03:37.687] 1048576 byte image read.
[13:03:40.578] J2534 API Version: 04.04
[13:03:40.578] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[13:03:40.578] Device Firmware Version: 1.07.2597
[13:03:47.437] -- connecting to kernel --
[13:03:47.437] kernel get version
[13:03:47.578] ECU HW part number : 1860A622
[13:03:47.593] ECU SW part number : 1860A62202
[13:03:48.343] -- unlocking ECU --
[13:03:48.343] starting session...
[13:03:48.359] requesting seed...
[13:03:48.359] sending key...
[13:03:48.656] interface close
[13:03:48.671] interface close
[13:04:05.578] J2534 API Version: 04.04
[13:04:05.578] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[13:04:05.578] Device Firmware Version: 1.07.2597
[13:04:09.390] -- connecting to kernel --
[13:04:09.390] kernel get version
[13:04:09.515] ECU HW part number : 1860A622
[13:04:09.531] ECU SW part number : 1860A62202
[13:04:10.296] -- unlocking ECU --
[13:04:10.296] starting session...
[13:04:10.296] requesting seed...
[13:04:10.312] sending key...
[13:04:10.593] interface close
[13:04:10.609] interface close
scientist
Re: 2006 JDM Mitsubishi Outlander
Postby ahmed » Fri Nov 13, 2009 2:06 pm
is it 2.4 mivec
ahmed
Postby scientist » Fri Nov 13, 2009 2:13 pm
Yes, 4B12
scientist
Postby Bruce Willis » Fri Dec 17, 2010 12:25 pm
i read it
Part 1860A622
Soft SMF036
may be Cal. 14010001
Out2.4XL JDM_MH8104F.rar
(219.76 KiB) Downloaded 964 times
Bruce Willis
Postby scientist » Fri Dec 17, 2010 1:36 pm
what method did you use?
scientist
Postby Bruce Willis » Fri Dec 17, 2010 2:12 pm
viewtopic.php?t=4886
MH7201F - 1997 Space Wagon 2.4 GDI; Galant 4G93 GDI; Mitsubishi Mirage Dingo 1.5 4G15 GDI;
MH7203FA -
Mitsubishi Carisma, Pajero, Eclips, Galant 2000-2004г; Montero Pajero 3.2 DID 4m41 2002
Hyundai Sonata 2.0 2004, Santa Fe 2.4 2001-2004, Tiburon 2.0 (Cupe), Matrix 1.8;
Kia Sorrento 2.4, Magentis 2.0 2000-2004;
MH8301F - 2001 Montero Sport 3.5L ; 2001 Pajero 3.0;
MH8302F - 2004 Galant 2.4L MIVEC; Outlander 2003-2005; Outlander CU5W 2.4 AT MIVEC 07/05 – 12/08; 2003 Montero Sport 3.5L 4WD; 2004 Galant 3.8L V6; 06-09 Eclipse GT;
MH8303F - 2006 Outlander AWD AT; 2006 Outlander 2.4L 4WD AT MIVEC;
MH8304F - 2005 Galant 2.4L; Colt 1.3 2004-2008;
MH8104F - Lancer X 1.5; 2005 JDM Outlander XL CME 2.4 Mivec 4B12
Supported CPU, the others didn't begin to do, as them normally reads and writes Open port 2.0
Bruce Willis
Postby NPS » Sun Dec 25, 2011 12:05 pm
I have exactly the same problem, pressed read and all gone, couldnt even read but when open the ACC all warning lights is on, fan is always on and the car wont start.
CAN ANYBODY URGENT HELP ???
NPS
Postby Bruce Willis » Sun Dec 25, 2011 1:01 pm
You can by MMCFLASH module 3 and use one button unlock to start the car and you can read and flash car. Evoscan.com diler.
Bruce Willis
Postby NPS » Sun Dec 25, 2011 10:34 pm
thanks for your quick reply, I am in Cyprus and I dont have the MMCFlash module, is there a way to start the vehicle? I dont wanna read or flash it anymore.
I only want is start and go :) if there is a way please help.
Do you mean that we mess the program in the ecu? I only press read didnt try to flash and this happen, is it possible to mess the ecu?
NPS
Users browsing this forum: Google [Bot] and 44 guests
