MH8104F ACD EVO X Reflash
Postby Bruce Willis » Sat Dec 04, 2010 3:25 pm
I made software. To whom it is interesting? Works under J2534.
Bruce Willis
Re: MH8104F ACD EVO X Reflash
Postby saro54 » Sun Dec 05, 2010 11:38 am
What is possibel to modify?
regards
saro54
Postby Bruce Willis » Sun Dec 05, 2010 1:05 pm
I offer only way to read and reflash bin.
Bruce Willis
Postby bulardas » Thu Dec 09, 2010 7:54 am
Hello,
I'm very interested about your option of reading this ECU. Can you share it?
S.
bulardas
Postby Bruce Willis » Thu Dec 09, 2010 8:28 am
No, I am selling it. At this point in the ACD have not tried. Tried to Lancer X 1.5, there is the same CPU - MH8104F. If a sufficient number of willing, I will buy a ECU ACD and Read the firmware (bin).
Bruce Willis
Postby bulardas » Thu Dec 09, 2010 10:57 am
I'm interested in buy it if possible.
Give me a PM if you want to talk with me in private.
Tell me price and the name of the program. I also have an Evo X ACD ECU to test it if you want.
S.
bulardas
Postby ofey » Wed Mar 14, 2012 8:19 pm
Did this progress anywhere?
ofey
Postby GMS » Thu Mar 15, 2012 1:50 am
GMS
Postby boymay22 » Sat Mar 17, 2012 4:28 am
Will this work on NA cvt lancer 4b11. I'm willing to buy if it works.
boymay22
Postby Bruce Willis » Mon Mar 19, 2012 12:41 am
boymay22 wrote:Will this work on NA cvt lancer 4b11. I'm willing to buy if it works.
What CPU it have?
Bruce Willis
Postby Bruce Willis » Mon Mar 19, 2012 12:44 am
ofey wrote:Did this progress anywhere?
EvoX ACD
8631A040.rar
(113.76 KiB) Downloaded 825 times
Bruce Willis
Postby boymay22 » Mon Mar 19, 2012 1:25 am
What CPU it have?
How to check the CPU? Did you mean ECU?
boymay22
Postby Bruce Willis » Mon Mar 19, 2012 8:16 am
boymay22 wrote:
What CPU it have?
Disassemble the ECU and find out what CPU. Have you tried to use the ECU FLASH?
Bruce Willis
Postby boymay22 » Mon Mar 19, 2012 8:20 am
yes i have used the ecuflash. so will this software read/write the TCU. Via obd2 port and tactrix cable?
boymay22
Postby Bruce Willis » Mon Mar 19, 2012 11:09 am
boymay22 wrote:yes i have used the ecuflash. so will this software read/write the TCU. Via obd2 port and tactrix cable?
No TCM only on the table.
Bruce Willis
