Postby Freon » Fri Feb 03, 2006 12:25 pm
I agree. I think it would be preferred that EcuEdit create a separate .XML file for each ECU, and that EcuEdit scans the working directory for all .XML files and incorporates them. Perhaps it would default to the ECU identifier for the filename. AG700F.XML or whatever. Or maybe it scans working directory when you open an ECU file for all potentially valid XMLs to save time on program launch.
Right now we would have to manually stitch the files together.
Not a big deal now, as it is more likely any one person will only need to regularly work on one ECU, but maybe next version or so.
Anyway, looking good so far!
Postby MRF582 » Fri Feb 03, 2006 4:44 pm
crisspyduck. I believe what you ask of ecuEdit, it already does. The XML definition file i have I started from scratch. Basically with nothing at all in ecuEdit.xml. So people can still just copy and paste their XML definitions into a new file which only has their ECU in it.
Here is a list of XML definitions that work confirmed for the 2004 WRX ECU.
http://www.scoobypedia.co.uk/uploads/Kn ... myDesk.jpg
MRF582
Postby epifan » Sat Feb 04, 2006 6:28 am
Ok, that's would be in next realease. Any files in same dir would be supported for read and write :wink: Now I'm working on HEX compare function 8)
epifan
Postby epifan » Sun Feb 05, 2006 10:22 am
New version ecuEdit v1.2.0.41beta
- adding HEX ecu compare: split screen, color difference visualization, navigation
- suppot multi-file XML description for read and write: ecuEdit scan self directory for XML-files, finding unique ecu description and link it. You can see linked xml-files in "file_name" attribute of <ecu_struct> tag in XML viewer. In write process changes would be only in linked <ecu_struct> - another tags in XML-file would not changed
Download ecuEdit v1.2.0.41beta
epifan
Postby crispyduck » Sun Feb 05, 2006 12:43 pm
epifan wrote:New version ecuEdit v1.2.0.41beta
epifan, this is great! Thanks very much. When I help out others now with identifying maps it's now much cleaner as I can simply create a separate XML config file and modify that - you even save back to the corresponding file - nice one.
Just looked at the new compare function. This is very impressive and works well on my wide screen laptop (1900 wide). In the software trade I use 'coloured diffs' frequently and recommend you take a look at WinMerge for a reasonable visualisation of differences. This is harder for you as ecuEdit already uses colours to shade maps. Perhaps there are some improvements here.
What are your plans for merging data? Would be good, as in WinMerge, to simply select 'merge' and that would copy across changes per difference, on a selected area, or the whole file. Again similar to say Microsoft Word's review markup. Anyway, food for thought.
Keep up the great work.
Postby epifan » Mon Feb 06, 2006 10:04 am
crispyduck wrote:In the software trade I use 'coloured diffs' frequently and recommend you take a look at WinMerge for a reasonable visualisation of differences.
in ecuEdit you can press F8-key and switch to color-mode only for different data. Any equal data would be default color. hope, that help you :wink:
crispyduck wrote:What are your plans for merging data?
Copy/paste in hex editor would be in next release :wink:
epifan
Postby ahains » Tue Feb 07, 2006 8:08 am
Why is there a delay when linking a log, with mention of it being a demo? I thought this software was going to be free? If not, I suppose I'll be inclined to get my log analyzer app to a working state so I can release it.
I don't have much free time, so I'd rather just ditch my project and use someone else's much-more-polished app :)
ahains
Postby Kha0S » Tue Feb 07, 2006 8:19 am
ahains wrote:Why is there a delay when linking a log, with mention of it being a demo? I thought this software was going to be free? If not, I suppose I'll be inclined to get my log analyzer app to a working state so I can release it.
Agreed. The delays are quite frustrating. :(
Kha0S
Postby epifan » Tue Feb 07, 2006 9:08 am
What can I say? Go ahead! Release it, may be openecu members like you app... I know that some of openecu members announce that they are also developing map editor. So, you can wait while they are release they projects.
And once again: I don't use any openecu.org sources for ecuEdit project. It's my own project, I'm use in it a set of shareware components (I'm purchase license on my own money) , so I can decide what functions in ecuEdit public release would be present. I'm also have't much free time, I'm support ecuEdit only in weekends or workday night... In first posts of this thread I say that I don't decide yet what I want to do with this project: woud be it freeware or shareware...
So, good luck!
epifan
Postby Kha0S » Tue Feb 07, 2006 9:09 am
epifan --
Don't get me wrong, I love what you've come up with. I just wish there was a way to pay you some sort of shareware fee to get rid of the delays! :D
Kha0S
Postby ahains » Tue Feb 07, 2006 9:16 am
epifan wrote:In first posts of this thread I say that I don't decide yet what I want to do with this project: woud be it freeware or shareware...
Epifan, I saw a quote of you earlier describing it as free and misunderstood this to mean you were stating it was to be a free utility. I went back and see now that the context of this was simply that you were offering a free DLL to Calvin, not the entire program for free. My mistake.
To be clear - I fully support your right to publish for-profit software. I don't think there is anything wrong with this at all, more power to you. :)
Just a case of incorrect expectations on my part.
This is a very nice looking app, by the way.
I do want folks to have a free & open source log analyzer to use, so I'll try to find the time to finish it up. Mine is in c# currently, but it should be very simple to port to Java if qoncept wants to bring that functionality in. I'll take a look at the enginuity interfaces to see if I should be proceeding any differently.
ahains
Postby ahains » Tue Feb 07, 2006 9:43 am
ahains wrote:I do want folks to have a free & open source log analyzer to use, so I'll try to find the time to finish it up. Mine is in c# currently, but it should be very simple to port to Java if qoncept wants to bring that functionality in. I'll take a look at the enginuity interfaces to see if I should be proceeding any differently.
Since the utility I was working on was very far from done and I have no idea when/if I'll have time to complete it, I just uploaded the source to the enginuity forum in case it is of any help at all to folks working on log analysis stuff:
http://www.enginuity.org/viewtopic.php?t=23
ahains
Postby epifan » Tue Feb 07, 2006 9:47 am
ahains wrote:Epifan, I saw a quote of you earlier describing it as free and misunderstood this to mean you were stating it was to be a free utility. I went back and see now that the context of this was simply that you were offering a free DLL to Calvin, not the entire program for free. My mistake.
Yes, I'm make offer to Calvin to use free DLL only with map edit support (at this time didn't log support), but Calvin decline it. So, all be changed after that, now I'm realize 90% all that I need for tune (I have some subaru-turbo-engine tuning experience)... I don't want to support SSM logger, it's easy and unnecessary, bc we have enought of loggers: DD, ecuExplorer.
P.S. Lets wait until Calvin release they ecuExplorer with map edit support... may be this release would not be free :wink:
epifan
Postby calvinc » Tue Feb 07, 2006 10:58 pm
any and all TARI software will forever be free!
this is not a race or game. i do this because i want free tools to be available for our community. maybe your motives are different?
Postby epifan » Tue Feb 07, 2006 11:24 pm
It's imho, bc you always skip my question about openness of ecu descriptions in ecuExplorer :wink:
P.S. imho, serious professional tool can't be free, may be cost would be less $50 but not free. Serious free tool smell utopian communism. OpenECU.org is not free, Colby sells his openport (imho, sell cost is much more then prime cost, and I know what for Colby spend part of openport's money) - it's clearly, bc money is motivation of development process...
epifan
