Error EJ204 DV ECU
Error EJ204 DV ECU
Postby leowaack » Fri Sep 03, 2010 1:57 pm
I'm recently purchased the tactrix cable do use ROMRAIDER, but can't get ECUFLUSH to read my ECU!
I can Log the ECU via RomRaider Log, but it won't work with learning view or EcuFlush!
The engine is a: EJ204
The Car is a: SADM Impreza 2.0R MT
The Ecu code is: DV
22611 AM800
A18-000 R8C 8Y18
cheers
sincerely
leo
leowaack
Re: Error EJ204 DV ECU
Postby leowaack » Sun Sep 19, 2010 11:18 pm
After a while trying still can't get it to work!
Can Someone help me?
Can someone get the definition for my ECU?
cheers
leo
leowaack
Postby radsdau » Mon Sep 20, 2010 4:46 pm
Impreza (non Turbo) probably has a JECS ECU, not Denso. Check that (should be written on the top). If it is not Denso, then sorry, it is not supported by ECUFlash.
If you can read the ROM but there are no definitions for it, post the ROM so the openecu community can work on generating a definition for it.
Postby leowaack » Tue Sep 21, 2010 10:44 pm
It sais HITACHI on top of it! So its not a DENSO, so it won't work! What can I do?
Can I use a WRX 07 DENSO ECU in my car???
Is there another solution to do e REMAP on my engine?
cheers
leo
leowaack
Postby leowaack » Wed Sep 22, 2010 11:14 am
I'm a beginer at this so can you help me out how I can get the ROM!
And I will post the ROM as soon as possible!
cheers
leo
leowaack
Postby radsdau » Wed Sep 22, 2010 3:27 pm
Honestly Leo, it's not sounding good. There may be a way but I don't know it.
Any chance of some photos of the outside and insides of the ECU, particularly the large chip?
Postby leowaack » Wed Sep 22, 2010 3:41 pm
OutsideECU
Here is a foto of the outside!!! the inside I will post as soon as possible!!!
leowaack
Postby leowaack » Wed Sep 22, 2010 10:45 pm
Inside of the ECU!
leowaack
Postby radsdau » Thu Sep 23, 2010 3:48 pm
Thanks- good pics.
Definitely not a Denso ECU though (as you already knew); the 'UJ' on the chip probably stands for UNISIA JECS at a guess. They merged with Hitachi in 2004.
Sorry- I can't help you with reflashing. It'd be nice if we knew how though.
Postby ferraz » Thu Sep 23, 2010 6:45 pm
Now we need to find a way to get the ROM out... Any especific board we should post this??
ferraz
Postby sfaragdas » Sun Mar 27, 2011 8:36 am
viewtopic.php?p=24818#p24818
there are some files if is some one who can do something with it??
sfaragdas
Postby sfaragdas » Sat Oct 22, 2011 1:32 am
so when EcuFlash dont support Hitachi ECU, is another software witch work with Hitachi ECU?? and work on Tactrix 2.0??
i read that the EcuExplorer can work with Hitachi ECU on Tactrix 1.3... but i don't have this one only OP2.0...
Or is some version of EcuExplorer witch work with Tactrix 2.0 ??
sfaragdas
Postby radsdau » Sun Oct 23, 2011 3:29 pm
As far as I'm aware Ecutek are the only company that offer a reflashing solution for these, and even then I'm not sure how reliable they are. I've heard several stories of bricked/unrecoverable ECUs as a result of attempting to reflash them.
Postby Sasha_A80 » Sun Oct 23, 2011 10:44 pm
Subaru MY 99/00 JECS ecu based on UJ WA12212920WWW UJ WA12212930WWW ( Mitstubishi m32150 processor )could not be flashed in a safe manner thru SSM. This is due to improper flash partition.
SSM bootloader code is erased before flash and if something goes wrong during flashing the ecu dyes.
More recent Hitachi ecus may not erase bootloader but have logical errors that may kill the ecu as well.
From probably MY06/MY07 safe reflash maybe done.
Sasha_A80
Postby radsdau » Mon Oct 24, 2011 4:16 pm
So there's no background reflashing process to recover these with if the SSM reflash fails?
Users browsing this forum: No registered users and 6 guests
