freakin wrote:CasopoliS, can you download the version 1.2.23 at the top should enable me to see what the problem is.If it errors can you get a screen shot of the message box that will appear with the app in the back ground so I can see the bottom box
you could also try putting these two files in your windows\system32 directory if they don't already exist (don't overwrite your existing ones if they exist)
I did not have the msxml2 file... so I put it in there. See attached screenshot. This comes up as soon as I select the ECU.
