2003 WRX Pro****drive
Postby peewee » Sat Jan 14, 2006 2:54 pm
Last week i had to update a WRX from 2005, it had already a 2003 PR**drive ECU!
Looks like its flashed with Ecutek???
AJ830pro.zip
(82.71 KiB) Downloaded 1434 times
peewee
Re: 2003 WRX Pro****drive
Postby crispyduck » Sun Jan 15, 2006 10:00 am
peewee wrote:Last week i had to update a WRX from 2005, it had already a 2003 PR**drive ECU!
peewee, Just sent you a PM. Do you think this is a standard PPP Ecutek or perhaps a custom Ecutek tune?
Postby peewee » Sun Jan 15, 2006 2:10 pm
The other file i uploaded earlier also seems a Ecutek file.
This is far to rich for the boost it give's. It run's Lambda 9.5 to 10.0.
So i think this is special made for Prodrive, the numbers on the ECU also are prodrive-numbers even with the Checksum of the file.
peewee
Postby JimbobUK » Tue Feb 07, 2006 11:06 am
Has anyone noticed the string at offset 0x2C4A0 (expanded to 192k)??? Looks like a Pr***ive marker...
"....PDPP2262005" - Perhaps P**D*ive Performance Pack 22/06/2005 ??
JimbobUK
Postby crispyduck » Tue Feb 07, 2006 12:31 pm
JimbobUK wrote:Has anyone noticed the string at offset 0x2C4A0 (expanded to 192k)??? Looks like a Pr***ive marker...
Oh yeh, just seen it. Seems very likely this is 'marker'. Well spotted.
I wonder if anyone else with a PPP can confirm they have similar markers by searching for P D P P, after setting ecuEdit in to 'char' mode?
Postby Hitokiri » Sat Feb 25, 2006 1:36 pm
<map name="AVCS???" type="3" active="1">
         <rows count="14" func_2val="[value]*50" func_val2="[value]" offset="#2BAAB" power="2" format="%6.2f" caption="RPM" desc=""/>
         <cols count="10" func_2val="[value]/8192" func_val2="[value]" offset="#2BAC7" power="2" format="%6.2f" caption="Engine Load" desc=""/>
         <data func_2val="[value]" func_val2="[value]" offset="#2BADE" power="1" format="%6.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
      </map>
You said this ecu came out of a 2005 WRX? What would this map be? Seems to me that its most likely AVCS map. would a 2005 Pro*rive ecu have AVCS??[/code]
Is it an STI?
Postby Spiider » Sun Feb 26, 2006 6:35 am
I don't think thats AVCS. My AVCS map looks very different.
Postby Spec C Wannabe » Wed May 03, 2006 5:29 am
How can I view the ROM image? The downloaded file doen't seem to have any extension such as .hex. And It comes in as 160Kb format. Can't find the XML definition of this ECU. I want to compare it with my 03 EUDM WRX.
Can anyone kindly help me with the procedure for viewing ROM image?
thanks in advance. :D
Spec C Wannabe
i'm beginner here
Postby whitescooby » Wed May 17, 2006 6:46 pm
Now I use MY05 WRX EUDM (A4TE300D) AJ830-8820.
After decat 1st , 3rd cat and change backbox & intercooler to STI ,can I reflashed "AJ830Pro_192k.hex" to my ecu? :roll:
(just convert AJ830Pro.zip to 192k , don't edit it)
whitescooby
Postby Jon [in CT] » Mon Aug 07, 2006 10:28 am
Spec C Wannabe wrote:How can I view the ROM image? The downloaded file doen't seem to have any extension such as .hex. And It comes in as 160Kb format. Can't find the XML definition of this ECU. I want to compare it with my 03 EUDM WRX.
Put the attached XML file in ECUedit's XMLDefs folder. Rename the ROM image to give it the .HEX file type. Run ECUedit.
The ROM is meant for the 2005 EU WRX.
AJ830pro.xml
(61.8 KiB) Downloaded 1147 times
Postby Freon » Tue Aug 08, 2006 10:16 am
That isn't an AVCS map. Here are some example AVCS maps:
Postby mafia69 » Mon Sep 10, 2007 9:35 pm
Has this map been tested on 05 EDM WRX? Does this require Prodrive BCS?
mafia69
Pro***drvie map?
Postby aschapman » Sun Jun 08, 2008 3:27 am
I've transfered the values for the ignition, knock correction, fuel maps and boost maps to an XPT2 map for a 2002 Bugeye WRX and this runs fantastic. Safe EGT's and no detonation
aschapman
Postby jardamarek » Thu Sep 22, 2011 10:08 pm
2aschapman:here you can please give your map?
jardamarek
